Question about Dryers
Beko tumble dryer DRVT 71 W wont heat - Dryers
  • 74 Answers
SOURCE: Dryer tumbles but doesn't heat
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Posted on Jan 18, 2006
localwonder
  • 6784 Answers
SOURCE: kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Aug 11, 2009
hunter19_46m
  • 7482 Answers
SOURCE: DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF
Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
Also could be a faulty motor..
Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
Motors will sometimes get a dead zone in them and this help move it from the dead zone.
Posted on Sep 26, 2009
  • 691 Answers
SOURCE: i have a beko DRCS68W tumble dryer but its not
you have to call service centre if under warranty or you'll invalidate it if you have a go. it will be the element or a heat sensor/switch most likely.
Posted on Jan 16, 2010
  • 45 Answers
SOURCE: i have a beko tumble dryer drc68w it's spinning
It is the heating element easy to replace.
Posted on Apr 28, 2010
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Hi I'm getting no heat from my beko drvt 61 w tumble dryer, have replaced the front thermostat, heating element and cleaned filter at front but still no luck is there any more I can do?
    Did you check fuse that might be near mains entry into the machine ? Why did you replace the heating element ?
    is rest of machine working ?like fan motor running ?
    sens more details so that I can pin point the trouble.
    Oct 03, 2015 | Beko Official Drvs62w Belt Poly V - 1967...
    Beko tumble dryer
    element and or thermostat...............cheers
    Jan 19, 2014 | Dryers
    Beko tumble dryer will not heat
    You either have a defective heating element, thermal cut-off or a fuse.
    May 03, 2012 | Dryers
    Can not unlock the child saftey locks on my beko tumble dryer
    First of all, thank you very much for choosing FIXYA today for your online technical support needs.
    Here is a direct link to the ONLINE USER'S MANUAL for one model of Beko Tumble Dryer (DRVT 71):
    http://fiftyeggs.blob.core.windows.net/bekoupload/manuals/DRVT71.pdf
    To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
    This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
    You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
    You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
    See page 16 of that manual for detailed instructions and illustrations on how to operate the CHILD LOCK feature on that particular model of dryer. Hopefully the procedure will be similar enough to help you out with yours.
    Basically it says to deactivate the CHILD LOCK feature, just press both the START/PAUSE/CANCEL button and the LOW TEMPERATURE button simultaneously, and then hold them both down for about 3 seconds.
    Otherwise just comment back here and let us know the exact model number of your machine so we can track down the appropriate information for you.
    I truly hope that was helpful to you.
    Good luck and take care.
    Joe.
    Dec 16, 2011 | Dryers
    Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
    go into service mode and reset
    to do this move to delicates turn on dryer and keep
    pressed down cancel button for about ten seconds release
    then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
    it is now reset, this worked for min a drcs68w
    Apr 23, 2008 | Dryers
    Dryers Logo
    374 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
