Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Info about Lite on nr146 motherboard
Hi, I've seen you post at fixya.com, I would like to know if you've fixed it.
I've bought an used motherboard of the similar kind but I can't find instruction manual to configure the front panel function (as switch-on and off, reset, etc.): CAN YOU HELP ME?
Thank you for answering ASAP and excuse me for contacting you, but I cannot solve my problem without
PS. If you have a pdf version, can you send it to me at castolfa@libero.it ? And if you have a paper version, can you scan and send the page with the connection scheme?
Thank you, another time
  • clikarbar May 14, 2009
    I want to scrap my DX2000 but want to use the motherboard on a different computer who's motherboard got screwed and all the ram and cpu fit this motherboard but the front panel switch and led panel is so unstanderd and full of numbers instead of wording. I am talking about jumper j35 on motherboard. Please help.
How do I turn the Demo mode off of my GE Upright freezer so my food will freeze
Lisa, you may have to contact the store where you bought it or contact GE. I looked all through the manual a couple time and nothing found on Demo mode. Check the attached links to contact GE for info., last link is USA. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Home GE Appliances
Contact Information
http://products.geappliances.com/appliance/gea-literature-search?Ntt=FUF20DURWW&x=10&y=9
Apr 12, 2016 | General Electric Upright Freezer...
My power light won't work.freezer runs ok so far.
The repair to this depends alot on how flexible you are. It is going to require, your getting down on your side, and seeing how much access you have to the lite device.
With no model number or make it is really hard to trouble shoot this. Basically, you may have a corroded connection or a burned out bulb. You can either replace the whole lite device, or you can install a second lite device that shows the unit has power going to it.
If it were me, I would just install a second lite. If your electrically savoy, then finding a power source would not be a problem, you could attach one to the vent on the bottom of the unit. They probably are about 2-4 bucks. You could drill a small fitted hole in the vent the covers the front bottom of the unit and press it in there and route the wire to where ever you choose.
If you want to know if you have power to the unit, what I have done in my garage (I have a freezer with the same problem), I just took a cheap radio, plugged it into the same plug outlet and turned it to my favorite station. Now, when I go to the garage, if the radio is ON, I am OK, if not,,,,,,, I open to the door and check and see if things are A-OK in there and find out why my power disappeared . It has only happen to me once in about 15 years, and it was a wall socket that CLICKS OFF when a wrong variation of voltage is detected.
So, I basically listen for the radio in the garage. Hope that helps.
If you want more info, post the model/make of the unit and someone will probably jump in there and help you out more specifically.
kindly,
Jim
Jan 16, 2014 | Danby DCF550W1 Chest Freezer
My True 23F has had extensive work performed since I bought it used. On two separate occasions, it worked well for a month, then shut down. At this posting, the compressor will not come on at all. ...
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
this should take you to their site for a manual on your freezer. I has info on the time clock and how to set it.
First, be sure it has the correct power to the unit. I would then check the temperature control. Be sure it is sending power to the compressor unit. If a contactor is used, is the coil on the contactor getting the correct power? Start there and let me know if we need to go further. Good Luck
Sep 12, 2010 | True 23 cu. ft. / 651 liter Commercial...
Kenmore Chest Freezer is Approx 13 years old. Currently power light is on but food is not freezing. Any Suggestions on problems.. Would a bad Thermosat do this?? or is it the Compressor?
Could be either...try jumping the t-stat to check that out and then check out these tips for more info..
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 13, 2010 | Freezers
MY FREEZER QUITS WORKING PERIODICALLY. IS IT THE THERMOSTAT OR WHAT?
Could be...try jumping the t-stat to check that out and then check out these tips for more info..
heatman101
Apr 12, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
I bought a used model MFC05M3BW5 chest freezer. I
Please see attached link for more info, but it appears as though your model has both an internal and external drain plug. Hope this helps
http://www.youserguide.com/wiki/Electrolux_216657700en-007
Sep 30, 2009 | Freezers
GE Profile Side by Side - PSS26lsrc - Unit whistles - like wind noise. Also does not produce as much ice as it used to. Need to pres 'quick ice' to get it to make ice.
I know of two things which can cause the noise. Since it hasn't always made the noise I would guess the motherboard is making it. Try to pinpoint the noise. Your motherboard is on the back. Part 801 on this diagram. If this is where the noise is coming from and you can put up with the noise, you can wait till you have more trouble with it. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PSS26LSRCSS&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-R-SERIES&diagramPageId=00009&componentDescription=SEALED%20SYSTEM%20&%20MOTHER%20BOARD&documentId=G0503214&backToLink=Return%20to%20Sub%20Components%20list
Another cause I've seen is because of the unique shape of the condenser coil. With the air pulled through it it can make a noise. It may help to clean the coil which may also help the ice situtation. It's part 730 on the diagram.
Sep 08, 2009 | Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
2,819 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
