Question about Philips GoGear SA178 MP3 Player
My GoGear wouln't recharge
I bought the gear 14 months ago, so the quarantee in Finland for 1 y is expired. I havn't been using the goGear after last summer so now when listening the radio with it the batteries went flat. The thing will not recharge! There is no sign of life in it even if I stick it in my computer in the USP slot. The goGear cannot be a once charged neve ever again gear. Do anybody know any solution how to recharge it? Thanks in advance Pirkka
Hey Pirkka...got the same problem! Did you find an answer?
Posted on Jun 09, 2007
  • Jay Phillips Jun 10, 2007
    Found an answer. Had to go to Philips support site
    and download the firmware upgrade software and run it...It resets it all the music but now it is charging!! Here is the link!
    http://www.usasupport.philips.com/produc...
    Good Luck!!
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Hello, I have a question: how many hours do i have to recharge my Philips GoGear SA018 mp3 player? In the guide its written to keep it for 3h and when the light is green it means its recharged,however...
If its new and your having this problem DO NOT hesitate to take it back. However most new gadgets when charging for the first time may require a bit more charging time than stated in the manuals.
If the problem persists take it back.
Aug 12, 2010 | Philips GoGear Clip SA018102S/02 2 GB MP3...
MP3 is not syncing
try pressing the reset button on the back you may need a pin or tooth pick because it is very small it should work then
Apr 22, 2010 | Philips GoGear Ariaz MP3 Player
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
Licence Problem with Philips GoGear 2GB
try removing the dmr on the files heres a site with a freeware program to do this i havent tested it yet but try it www.downloadatoz.com/...drm.../drm-removal-freeware.html
Sep 25, 2009 | Philips GoGear SA3125/37 MP3 Player
How does the go gear gets recharged ? Please help.
It gets recharged by the USB pulged in your Laptop. ( Switch the Lock in OFF Position which is IMP )
Jun 24, 2009 | Philips Sport Personal CD/MP3 Player
Unable to recharge
Make sure the hold/lock is not engaged
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Philips Go Gear MP3/Video Player 2 GB (Model SA3125)
The Phillips Go Gear is not compatible to Windows Vista, and there is nothing one can download to make it compatible. I contacted Phillips, and they said that there are no plans to update the software so that it works on Vista. Pass this to everyone that is having a similar problem. Contact Phillips on their website, and request that the Phillips Go Gear software be updated to include Windows Vista. If more people raise a stink (especially threatening never to buy Phillips products), maybe something will be done.
Dec 25, 2007 | Philips GoGear HDD1830 MP3 Player
Philips GoGear SA178 MP3 Player Logo
96 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
