I have 50" PF9966 flat TV , not sure if is HD ready ? 2006 model how do i find out , nothing showing in guide
  • 4,234 Answers
There are a few things to consider here. First, if you are using cable or satelite, the changeover has no effect on you anyway. If you are using an antenna, the changeover to a digital broadcast signal has already been in place for a while. The set should be able to auto-detect these signals. I believe that most of the models from 2005 on had digital signal tuners available. This is not the same as a "digital" tuner. A digital tuner only means that the stations are tuned digitally but are still analog signals. The changeover will be to change the analog signals to digital ones that require a smaller frequesny band for broadcast thus opening up more space for additional channels.
Hope this helps,
Dan
Posted on Jan 05, 2009
Where is lamp location in polaroid 32 in hd tv
I'm not sure which TV you have. The Philips 50' plasma does not have a backlight. The Polaroid 32 can have a incandescent or a florescent backlight. The backlight is accessed by removing the back of the TV and replacing the lamps. There can be 1-4 of these light for florescent and 1-*** number of lights if incandescent, depends on the design, model, features, price point.
Aug 03, 2012 | Philips 50PF9956 50 in. HD-Ready Plasma...
Where is the bulb located on model 50V500
if you have on screen display of any kind, menu etc the lamp is not the issue.
May 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
The TV was working 10 to 15 minutes, and tried the different inputs of TV but showed the same problem. manufactured on nov/2006 Many thanks
are you saying that your tv stop working ?please explain the problem of your tv so you can get help. any how your tv is a old set replace it..to repair it will be expensive.
Sep 13, 2011 | Nakamichi VU50P 50 in. HD-Ready Plasma...
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My tv just blinks codes when i turn it on. it is a 50 INCH LCD HITACHI TV MODEL 50V720 .
first of all my friend that is not a model # for an LCD TV. that is a DLP TV. and your problem is the lamp, replace the lamp.
good luck
Jul 28, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
DIGITAL/HD CHANNELS
hi there, i have the LG 50in Plasma and just updated the channel connection by doing the following:
1. Make sure your remote is in "TV" mode.
1. Press the Menu button.
2. Highlight "Auto-program" (Should be the first item on the Menu)
3. Scroll over to "To Start" and press OK.
The TV will automatically search for all available analogue, digital and HD signals and may take a few minutes.
Once complete, it will return to the last program you were on and you will find all channels available.
To check the guide or the time, you need to press the "guide" button. Make sure your remote is in "TV" mode. Alternatively, pressing OK at any time shows you the time and channel that you are on.
Hope that helps!
jp
Sep 20, 2008 | LG 50PX4DR 50 in. Plasma TV
Hitachi 60V500A
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50vs69a
have power supply normally the voltage regulator gose bad normally start str f668b
Apr 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
