Only the orange light glow when being charge, what should I change ?
SOURCE: psp not charging
My son has a Nintendo DS that had the same problem. The battery was no good--wouldn't take a charge. We bought a new battery and that didn't fix it either, so don't waste your money. All we can figure is he must have dropped it or something happened while it was in his backpack (kids!). We tossed it and got a new one. I'll be upset if it's something simple!! Good luck to you.
SOURCE: psp trouble
it might be a bad battery. try useing i diffrent one. like from a friend or something.
SOURCE: when i charge my psp the orange light comes on but
does the green ligth stay on without the charger, it maybe bricked, and it may need files to fix the problem! or could be battery but the psp should start with the charger on
SOURCE: I have a PSP that I charged overnight and a orange
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
SOURCE: My PSP will not turn on unless it is plugged into
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
