Question about Mackie SRM350V2 POWERED SPEAKER
Mackie srm 350 v2 lights blinking
Lights are blinking
3 Suggested Answers
  • 5603 Answers
SOURCE: How do I replace the fuse on a Mackie SRM 350 v2?
The fuse is inside and is to be replaced ONLY after you repair the cause of it blowing. Additional damage may result if repair is not made first. Power it up with a 150 watt light in series with the power cord as a resetting fuse. When light remains out, unit should be good.
The fuse is mounted on a circuit board behind the power input connector.
Here is a link to a service manual that is probably close to your unit:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down at the web page to a small link that says "Get Manual" Click on that and after download unzip the file... it is free... ignore the winrar thing...
Posted on Apr 02, 2011
  • 8 Answers
SOURCE: ONLY GETTING MUFFLED SOUND FROM
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
Posted on May 05, 2011
Mackie srm 350v2 speaker packed up
I believe there is an internal fuse in these which, according to a friend who has these, seems to blow occasionally for no apparent reason. He has also had to send two back for replacement and would not buy again, they seem to be inherently unreliable although they sound great.
Jan 02, 2013 | Mackie SRM350V2 POWERED SPEAKER
Do i have the right fuse
This speaker at full power draws average 1.3A at 230V and 2.5A at 120V. Mackie's recommended fuses are in line with this so your fuse is actually too high a rating. It is possible you are using cheap fast blow fuses or are over-driving the speaker (which should cause the fuse to blow) These speakers are only capable of 118db sustained (@1M) so cannot be expected to cope with anything but small venues or gentle music.
Dec 07, 2012 | Mackie Srm 350
Need spec on Mckenzie loud speakers 12'' dual cone 85 watts rms
What\'s the question, are you asking about eyebolts, SRM 450 or McKenzie speakers?
Let\'s assume speakers. These are quite nice vintage speakers and were fitted in a number of units back in the day. Depending on the use they are going to be put to you\'ll need to find the dimensions of similar boxes for the same use and speaker size from (ideally) makers who used these speakers or something similar. It\'s going to be a bit suck it and see and will also depend on if you are looking to use an infinate baffle, sealed or vented enclosure.
Try Speakerplans com
Sep 23, 2012 | Mackie Pa-a1 Eyebolt Kit for Mackie Active...
Problem with the Mackie SRM 450 v2
It would be very unusual if the blue LED is burned out. They should last a million years. I suspect the power supply has a problem.
Apr 03, 2017 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
What size internal fuse on mackie srm450v2 speaker
Mackie say this is not a user service part. If the fuse has blown there is probably a fault in the unit being their reasoning. I know for certain they tend to blow for no apparent reason so it is worth giving it a go. They are 5 x 20 Slow or time fuses. 7A for 120V and 4A for 230V
Jul 13, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
Apr 01, 2011 | Mackie SRM350V2 POWERED SPEAKER
Problem with Mackie SRM450V2: HFsignal bleeding through LF driver,low HF OUTPUT also. Filter problem i suspect.
There is an entire crossover circuit inside that is BEFORE the amp section. There are 2 separate amps: one for HF and one for LF. Can you describe the noise you are hearing in more detail? Is hte sound effected by the gain controls at all? What happens without any input?
Thanks,
Dan
Feb 10, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
Mackie SRM350V2 POWERED SPEAKER Logo
412 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
