Question about Kenmore Sewing Machines
I have a Kenmore sewing machine Model # 158.460. the motor runs and the belt turns, but will not sew. It worked fine for a few hours and then stopped. I do not have a manual for it.
Machine worked fine for a few hours, belt turns, motor runs, but will not feed material. Checked for jammmed threads. Machine is threaded properly and same thread is on bobbin.
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
Kenmore sewing maching model 17922 seizing up. I have oiled it and cleaned it but it still will not work. Suggestions? It was working fine, then just stopped.
Depends with what and where it was oiled. Use only fresh good quality sewing machine oil--NOT 3-in-1, WD-40, cooking oil, or grandma's old stinky brown sewing machine oil.
When a machine has seized, I prefer using liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Open the top, side over the needle bar, and the bobbin area. Gently wiggle the handwheel and apply 1-2 drops each place where metal rubs on metal. Do NOT oil belts, synthetic gears, cams. Then direct hot air from a handheld hairdryer into the internal mechanisam. Get the metal parts hot. If it still doesn't move freely, repeat. Avoid over oiling as the result is you will be spending a lot of time mopping up the excess.
In the future, oil the shuttle/hook every 8 hours of sewing, do a light all-over oiling (as described above) every 40 hours of sewing, or every six months if the machine is in storage or not in regular use.
Oct 23, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
HOW TO CHANGE THE OLD BELT ON THIS MACHINE
The one thing on a sewing machine that needs the most repair work is the belt. The sewing machine belt is a piece of rubber that makes the wheel turn and the needle go up and down in a sewing motion. If the belt is in bad shape, the sewing machine will not work. Sometimes while sewing you may notice a burnt rubber smell. When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; just make sure you have the proper belt.
Dec 08, 2015 | Sewing Machines
Model 1802. The hand wheel will turn only with hand force.
This might sound too simple but it might need to be thoroughly oiled. I just got one of these machines from a friend -- it had the identical problem: I couldn't turn the handwheel. The motor was working but the machine would not function. I blasted it with WD40 and then thoroughly oiled it with sewing machine oil. Within a half hour it was stitching just fine. If you use WD40 to free it up, be sure to thoroughly oil it with sewing machine oil immediately after because otherwise the lacquer in the WD40 will eventually gum it up again. Hope this helps.
Jul 31, 2010 | Kenmore Sewing Machines
I have everything in place to sew, the needle is in the fabric, I push the pedal, and it won't go and makes a horrible noise, the wheel turns about 1/2 a turn and then just stops.
see if it will work without the needle .. make sure the needle is not bent .. make sure you dont have a single (non zigzag) foot on the machine while its in zig zag mode .. the needle will hit the foot in this case .. if the machine will run without a needle and fails even with a straight needle then there could be a timing issue .. the top part of the sewing machine is syncronized with the bottom part via a shaft and some gears .. these are adjustable by a tech person .. everything has to happen at the right time if that relationship is changed thru slipage or wear then the machine may jam up .. also if some cloth, thread or lint is cought in the bottom unit it can cause the trouble .. will it turn by hand ?? if it turns by hand freely but wont turn with the motor ... and it makes a lot of noise .. you may have a loose belt from the motor .. if its a cog belt then it will make a shuddering noise as the drive gear slips over the cogs .. the belt tension is adjustable .. it just wants to be snug not tight, not loose ..
Sep 19, 2009 | Singer 7444 Mechanical Sewing Machine
I need to replace the motor belt on a Kenmore sewing machine
You can find the belt you need here:
http://www.sew4less.com/QuickSearch.php
if not in stock try here for the part you need:
http://www.a1sewingmachine.com/belts.html
Jul 07, 2009 | Kenmore Sewing Machines
I have a Kenmore 1516 that will not sew. The
If you can take the top cover off, try spraying the whole machine works with WD-40. Let it sit for a few hours to start working and then try to move things slowly.. If things start to loosen up but not totally move, spray it again and let it sit over night and try things again.
Kelley
Apr 26, 2009 | Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
