Power problems when you start, the power just drops and the laptop does not start
Is this happening when its connected to adapter / without adapter?
Try replacing your battery, if problem persists then it might be the problem of your processor fan. Check if its running properly. Not running / running too slow will cause the problem.
Posted on Nov 07, 2012
Battery will not charge\]
remove the battery for 60 second and charger from laptop and press the power contd bot ten for 60 second live it for 1 hour and inset it battery do not start the laptop just charge it your laptop first that all your problem will solve soo ples till me
Jan 22, 2014 | HEWLETT-PACKARD Computers & Internet
I have a Transcend JF V10 Flash Drive. This is not detected by my laptop running Win 7. The same flash drive is detected in my samsung smart tv. I have another transcend 4 gb flash drive, which is detected...
Click Start, then type device manager in the Search box, then click Device Manager.
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete, restart your computer. Your USB controllers will automatically install.If your problem still exists do the following:
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
Jan 01, 2014 | Transcend Electronics - Others
I need a list on where to start on fixing my power problem on my Dell inspiron 8600
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 07, 2013 | Computers & Internet
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
How to reboot laptop
click on lower icon flag at shut down ,click arrow at drop box click on restart.
Jan 05, 2013 | Computers & Internet
Can you help me fix my Dell Studio 1558 laptop? It doesn't boot?
Dropping a laptop is never good news. Have you tried to Cold-Start the laptop, unplug. remove battery, leave battery out for now, plug in try to start normally. If that fails, Did you remove the HDD and reseat? The damage from the drops may have jarred something loose. Do you get activity, light blinking, from the HDD? The DVD/CD?
Nov 14, 2012 | Computers & Internet
My laptop frequently drops its wireless connection
Check the power saving settings, it's possible that your wireless card is going in power saving mode. This could be done through the operating system, or maybe in the BIOS.
Apr 16, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I dropped my laptop
any lights on the front display? (Also check the light on power adapter)
Dec 26, 2008 | Gateway M675 Notebook
Laptop HP Compaq nx9420 Screen goes Blank
From the Symptom you described, it seems like the thin video cable's connector is loose and is barely connected to the video adapter on the motherboard. You won't be able to tell until you remove the Keyboard and/or the Palmrest to check it. Also, there is a slim possibility that the Laptop has knocked something loose and is going into sleep mode. Normally, a Laptop user can configure it to go into Sleep mode or 'Hibernate'. These settings can be found in the Control Panel under 'Power Settings'. http://www.Computer-Repair-Today.com
Jan 06, 2008 | HP Compaq nx9420 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
