Question about Dishwashers
Siemens Dishwasher - no wash cycle
Hi Tresilla
Probably the first thing is to identify the model! I acquired the appliance when I bought my current house about 6 years ago and I dont have any info on the dishwasher, apart from being Siemens. Do you know where the model number is stored?
The background to the problem is that the outlet blocked up a few weeks before Xmas. This also happened to me a few years ago and I resolved by taking outside and using a hose pipe applied to the outlet.
I tried this solution again but internally one of the connectors parted. I ended up, probably inadvisedly, turning dishwasher upside down to drain water. Subsequently removed blockage by blowing up a tube inserted into outlet. Dishwasher now drains OK but just doesn't go to wash cycle.
I read about the anti flooding device. Visibly that looks OK ie not stuck in up position, no water in base.
Can you help me with my next move?
Cheers
Stewart
  • 3 more comments
  • wolfysmith_2 Jan 05, 2009
    fyi I found te model no - t'is SE24200GB.
  • wolfysmith_2 Jan 12, 2009
    OK Ive followed the suggested link which tells me that either the float valve is defective or the water inlet valve is defective.
    Re the latter, are we just talking about where the water supply enters the back of the dishwasher. Or is this located somewhere internally - rem this is a Siemens dishwasher SE24200.
    Re the latter, the float isn't stuck physically. Is there a way to test whether the switch is working.
    Cheers
    I haven't quite got the hang of this website! - someone suggested going to
    http://www.repairclinic.com/0088_9_1.asp...
    but that solution has disappeared now - my last comment was in relation to that suggestion. I dont think the timer is a problem.
    I don't think there is a problem with the water heating cycle nor the timer. Water is simply not entering the dishwasher. I need a little more info about checking the float valve or the water inlet valve on a Siemens dishwasher. Cheers.
    It was the antiflood device. It looked as if it wasn't stuck or anything but after a few gentle wiggles, dishwasher decided to work. Much obliged.
    Brigadier General:
  • 8,619 Answers
Hi!
The fault is with the flow valve and pressure chamber and an associated filter that is blocked. Also, USE A RINSE AGENT i.e JET DRY ON ITS HIGHEST SETTING and see if it gets unblocked.
Posted on Jan 12, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 12, 2009
    Power OFF, Plug OUT.
    Remove bottom basket completely.
    Remove filters.
    With the aid of a torch, examine the sump area. There is a tangential opening at the 6 O'Clock position, on the actual curved wall of the sump, at the front of the sump. This leads off left, upwards and backwards. It is a corrugated plastic pipe, and leads to the water level sensors/measuring devices.
  • Rylee Smith
    With the aid of a slim bottle-brush, bent into a gentle curve, GENTLY & CAREFULLY rod the pipe out. You may get a substantial amount of greasy deposits out. This is quite a common fault.
    Replace filters and bottom basket, and run the machine.
    The base may also have water in it, causing the drain pump to run indefinately.
  • Rylee Smith
    Also, remove and check the control board and check that everything looks normal like No burnt solder or no burnt connections or a burnt solder joint
    Sergeant:
    Novelist:
  • 326 Answers
This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
  • 10,515 Answers
It is possible that the drain is plugged. Remove the round plastic drain cover at the bottom of the dishwasher. Feel around for stuff that might be plugging the outlet. BE careful however because there will be a sharp spinner blade in front of the drain opening. Kind of like the blade in a blender. It is supposed to chop food solids before they enter the drain and the pump...
 U may refer to the BEST link ever for siemens dshwasher :)
http://www.keepingupappliances.com/repair-help/dishwasher-wont-continue-the-cycle
Thanks.
    Genius:
  • 1,239 Answers
Hi When initiating a wash cycle the machine will not start and the red inlet/outlet light comes on or what ?
I have experienced a similar fault. When initiating a wash cycle the machine will not start and the red inlet/outlet light comes on. I usually follow a set procedure as follows (But you can skip this lot and go straight to 'plan B' described at the end if you like.....).
1. Firstly I switch off the electrical supply at the outlet then remove the filter and check the water level in the sump - usually the water level is too high and I use cups and a sponge to transfer water to a bucket until there is virtually no water left in the sump.
2. While down there I flick over the metal retaining spring clip (it hinges over into the sump) then lift out the impeller cover and inspect each paddle and remove debris if there is any blockage.
3. Refit the impeller housing by entering the outlet pipe first and pressing down firmly - clip the metal retaining spring over the top until secure.
4. Clean and refit all the filters.
5. I then inspect the outlet hose by releasing the connection to the outlet pipe - occassionally this can be slightly restricted or clogged but is often free running.
6. I isolate the water inlet and unscrew the brass inlet connection (mine has a bulky unit that has a plastic cover and I suspect contains a device to detect inlet water flow). Upon inspection there is a small screen/filter and on some occasions this has appeared to be clogged up with hard water limescale deposits but is easily cleaned with a toothbrush.
7. Reconnect brass inlet connection and open water isolation valve.
8. Electrical power is reconnected and I try to initiate a wash cycle.
9. If the red light for Inlet /outlet still comes on and the unit still won't work I then carry out plan B ...
Plan B is really simple. Switch off the electrical supply, go and have a cup of tea. Return to the dishwasher and set the temp dial to 'STOP'. Reconnect the electrical supply, switch the unit to the ON position then press the start button and select a wash cycle. The inlet outlet light has gone out and the unit starts its wash cycle. Hey presto... Now why didn't I try plan B in the first place?
  • 565 Answers
Best help u can get from this number its the siemens service - call 1-866-447-4363
    Scholar:
  • 160 Answers
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
  • 679 Answers
Try the link>>>
http://www.repairclinic.com/0088_9_1.asp#Level1_9
My siemens dishwasher model SL34A002UC/22, does not go to the dry cycle. It keeps washing and stays on the last minute and doesn't stop. Could it be the control board?
it is probably the timer , if u open it and pull off the plastic lining inside you can get at it just unplugs pay attention to the little peices and springs so u can put it back together ...
Apr 08, 2011 | Siemens Dishwashers
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My siemens dishwasher bottom arm does not spin to clean the bottom basket of dishes. Everytthing else works fine. I have removed and cleaned out all washing arms and plastic water carrier inside...
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 23, 2011 | Siemens 24 in. SE64A630GB Built-In...
My dishwasher isn't getting up to heat and hence dishes are not cleaned and are wet at the end of the cycle. Any suggestions much appreciated.
Dishwasher
How to Buy
heatman101
Jan 15, 2011 | Siemens 24 in. SE64A630GB Built-In...
Hello. Our siemens built-in dishwasher is not cleaning properly in the upper tray. While there is some element of cleaning there remains a residue in the upper tray only.
Dishwasher
How to Buy
heatman101
Dec 17, 2010 | Siemens 24 in. SE55A560 Built-in...
The heating / steam cleaning cycle does not seems to be complete
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
ll
Jul 16, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher is not cleaning dishes
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Siemens dishwasher does not wsh the dishes
heatman101
eqrte
Jun 16, 2009 | Siemens 24 in. SL84A305UC Built-in...
Insufficient water to wash
Siemens and other large companies do not generally produce appliances that do not perform the intended function so it would be reasonable to assume your machine has a fault.
You will probably need expert help to cure that fault...
Feb 01, 2018 | Siemens 24 in. SE20T590GB Free-Standing...
Identifying my dishwasher
On my Siemens all the ID numbers are on the top of the door, on the metal, "inside" part of the door.
Mar 18, 2008 | Siemens 24 in. SE53200 Built-In Dishwasher
Dishwashers Logo
255 people viewed this question
Top Dishwashers Experts
