Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony 37" Flat Panel Bravia--cant change from channel 2?
Product plugged into cable line only and cannot get it off of channel 2? Is there a channel set up or something?
  • pauls671 Jan 05, 2009
    Perfect! went into menu and initial set up screen. Works fine now. Thanks very much!
    Novelist:
    Scholar:
  • 67 Answers
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Posted on Jan 05, 2009
Cannot get digital service although all other tv actually get fed from a satellite. Seems cannot change the country of origin when initiating tuning
Posted on Jan 31, 2010
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Picture splits into two halves
Change the box it will solve the problem.
Jun 02, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
I have a sony kdl-52S5100,and every so often when i switch channels i get only half a screen,{on the left side of tv}i can channel up and down abd it stays that way untill i push the input button on my...
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
May 17, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Cant get TV to go off of channel 2?
try menu, then set up, make sure tuning band is set to cable if u have cable or air if your using antenna, then go to auto serch for channels
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
556 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
