Question about Intermec EasyCoder® PM4i Printer
Intermec 3400e ribbon tension too tight
Tried to changed ribbon, now, the ribbon is not advancing it is very tight.
SOURCE: my Intermec Printer is giving
I am need the softwar printer hp 5150 diskjet color
Posted on Jan 28, 2009
SOURCE: new intermec pm4i printer will not rewind ribbon
configure your printer in Thermal Transfer Mode
Posted on Jul 29, 2009
e-Guru
  • 3917 Answers
SOURCE: Intermec 3400E: Label prints
Hi
There are three common causes for this problem:
o An incompatible printer driver.
o The paper source is set incorrectly on a dot matrix printer.
o A custom label Down Page or Page Length setting is incorrect.
The resolution for each problem is listed below. Incompatible Printer Driver.
Contact the printer manufacturer to obtain the latest version of the driver for your printer. As an alternative, see your printer documentation for other printer models that your printer can emulate. Then, install the printer driver for one of those models.
For information about installing printer driver software in Microsoft Windows, see your Windows printed documentation or online help.
Paper Source Set Incorrectly on a Printer
1. On the File menu in Works, click Page Setup.
2. In the Page Setup dialog box, click the Source, Size, And Orientation tab.
3. Select the correct option in Paper Source. For example, if the Paper Source is set to Manual Feed and you are using tractor fed labels, change the Paper Source setting to Tractor Feed.
4. Click OK.
Custom Label Settings are Incorrect
5. Open the Word Processor label document in Works.
6. On the Tools menu, click Envelopes And Labels.
7. Click Custom Label.
8. Make sure the Down Page text box correctly reflects the number of rows of labels on the page you are using. Click OK.
9. Make sure the Page Length text box correctly reflects the length of the page you are using.
10. Click OK. Click Change Label.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 26, 2011
printertech1
  • 96 Answers
SOURCE: ERROR: ribbon fitted (printer: intermec
TTR- Thermal transfer- set for using a ribbon. DT- Direct thermal - set when using thermal labels but no ribbon.
Posted on Sep 23, 2011
  • 58 Answers
SOURCE: when i give print ribbon come with paper
sounds like you have the wrong type of ribbon (POOR QUALITY) OR the ribbon could be set up wrong on the printer or you need to reajust the paper and ribbon guides.
Out of interest how old are the ribbons you are using - do you know the manufacturer date? A few years back I had this problem with one of my clients and it turned out that the ribbons had been sititng on the shelf for 4 year! These degrade quickly!
Posted on Nov 24, 2011
Why error on Intermec pm4i "ribbon Out"?
Sounds like there isn't enough tension or when the printer stops the roll is still moving forward. It usually moves quickly in reverse to pick up the slack but it's already too late. I've seen people put light boxes or other objects on the ribbon to help with the tension yet still let the ribbon pass by. I've had this happen but we were using an a spool that was longer and subsequently heavier than the standard retail. Our rep provided us with a hyperterm script we could send to the printer to account for the heavier weight, unfortunately it didn't really work until it was 10%-20% through the roll.
Jul 24, 2014 | Intermec EasyCoder PM4i Printer
ERROR: ribbon fitted (printer: intermec PX4i ) where and what needs to be changed in the settings?
Sep 06, 2011 | Intermec EasyCoder® PX4i Label Printer
Yellow light is lit (Empty/Pause) but there is paper in printer.
I've found that if the ribbon core is slipping on the TTR supply hub, it causes the ribbon sensor to think the ribbon is not moving. This, in turn, causes the yellow light to come on. Take off the ribbon and replace hub core locking bracket (p/n: 065375-003). I have also found you can bend the bracket enough to work if you don't have any on hand. I hope this helps with your problem.
May 03, 2011 | Intermec 3400E Thermal Label Printer
The intermec is show a "ribbon fitted" error on the machines screen
its because the printer is setup Direct Thermal, and the sensor see ribbin present. need change setings.
May 21, 2010 | Intermec EasyCoder® PX4i Label Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Network Card
INTERMEC TECHNOLOGIES 72884
Internal EasyLAN Ethernet Card (for the 4420e, 4440e and 3400e)
Oct 22, 2007 | Computers & Internet
Intermec EasyCoder® PM4i Printer Logo
41 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
