Question about Sony KDF-50E3000 Television
Sony KDF-50E3000 Television 6 BLINKS - Sony KDF-50E3000 Television
  • 84 Answers
SOURCE: standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Posted on Jun 22, 2008
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
SOURCE: Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Posted on Nov 26, 2008
  • 41 Answers
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
electronick
  • 505 Answers
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Posted on Dec 09, 2008
KDF-50e3000 Sony TV has blinking red code 5X. Is this an easy fix ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 27, 2016 | Sony KDF-50E3000 Television
Lowb error
3 blink is a open door for the lamp , also is for bad s/w one is for the door lamp and the other one is for the lamp it selt , you going to have to take the cover off and look for these little s/w and jump the wire , these should fix you problem
Feb 12, 2012 | Sony KDF-50E3000 Television
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 17, 2011 | Sony KDF-50E3000 Television
2007 Sony TV KDJ-50E3000 keeps cycling on and off
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it as tv shuts off and turns On itself is symptom of dying lamp that need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Mar 28, 2011 | Sony KDF-50E3000 Television
How many projection bulbs does a sony kdf-50e3000 have
Sony KDF-50E3000 is LCD Rear Projection tv that has one lamp as back light source and optical unit (light engine) generates image that projects on front screen of tv, it is similar to multimedia projector technolog.
Lamp part number is F93089000 XL-2500 utilized in this model.
Thanks.
Feb 17, 2011 | Sony KDF-50E3000 Television
Bought a Sony KDF 50E3000 deom from Best Buy. ''Store Mode''nstruction came up and I hit the wrong option I guess. Now I get sound but no picture from my DIrecTV connection. W/O a picture I can't find...
Do this from the remote while the TV is off. In sequence (within 3secs) press "Display" - "5" - "volume +" - then "power". wait 30sec then press "8" and "enter". This will reset the TV back to factory settings. If you still have trouble then something has failed in the set.
May 19, 2009 | Sony KDF-50E3000 Television
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
Sony KDF-50E3000 Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
