Have a stbhd2010 technika cant get sound on hd channels
NO SOUND ON HD CHANNELS
SOURCE: No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Posted on Jan 06, 2009
SOURCE: No sound on NON HD channels
  • 10 Answers
SOURCE: sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Posted on Jan 08, 2009
micromend
  • 748 Answers
SOURCE: I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Posted on Sep 24, 2009
JT92677
  • 13 Answers
SOURCE: I have a VIZIO LED/LCD VF551XVT hooked up to a
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Posted on Feb 04, 2010
SOunds shut "off" when changing from HD channel to non-HD channel.
I think you need to look at the sound settings. In particular the type of sound. HD channels often carry AAC sound, suitable for Dolby 5.1 and Standard Channels don't. So the sound system will switch modes when you change channels. However the receiver is not switching back to picking up PCM signals, the type used on SD channels.
Jan 01, 2018 | Harman Kardon AVR 7000
No sound on Technika HD TV when using my Xbox using HDTV cable
i cant get soun when playin my xbox 360 on my technika tv. how do i obtain sound?
cheers
Jan 12, 2010 | Microsoft Xbox 360 Console
I cant get full screen on amy channels other than mu HD channels
see if the remote has a hd zoom button. if it does use that on the non hd channels.
Apr 16, 2009 | Televison & Video
No sound for HD channels Denon 2307
Need more detail - What is your TV source (directv, cable, etc,) Also - how is it connected to the Denon?
Apr 01, 2009 | Denon AVR-2307Ci Receiver
Ive just been given a Technika television LCD19DVDID 308 and I can't find out how to watch analogue channels,can anyone help me please?
have fitted a new aerial as tv was connected to sky and now cant get any freeview channels keeps saying no signal what am i doing wrong
Mar 16, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
No sound through channels on hdd dvd
If you are taking output from the Red, Green Blue connectors (Component) from your video source and plugging them into your hd dvd recorder, you need a sound channel as well. The S-video carries both audio & video but not in high-definition. Sounds like you've got the 3 channels for your video (RGB-component) connection now you need an audio signal into your HD DVD recorder. That will be 1 fibre connection or 2 cables. Let me know if you get it working & good luck!
Nov 13, 2008 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
