Question about IBM ThinkPad T42 Notebook
Monitor blanks out / Laptop restarts
My laptop stays on for a few minutes and then the monitor seems to blank out. Only the battery(coz its plugged in) and the the one next to it ..the z symbol stays on. Dont know if it is a particular mode that it goes into..or something else is wrong..Any ideas?
  • The problem seems to be the connection of the keyboard/mouse with the motherboard. When i use another mouse and keyboard connected to the laptop, it seems to be working fine.
  • 57 Answers
I have had the same issue with many IBM T4x series laptops. THE PROBLEM: BAD SOLDER ON THE VIDEO CHIP. SOLUTION: RE-FLO VIDEO CHIP
This is a way to test the Video Chip:
START WITH UNIT POWERED DOWN AND UNPLUGGED
1) remove the keyboard screws then lift up the keyboard enough to reach the video chip. DO NOT DIS-CONECT THE KEYBOARD FROM THE MOTHERBOARD2) Connect the power supply. Reach in and apply pressure to the video chip with one finger.3) As you continue to apply pressure to the video chip press the power on button to boot the laptop.If you SEE VIDEO on the screen while you are applying pressure and DO NOT SEE VIDEO when you remove pressure, the solder is bad on the video chip and will need re-flo.Search Google for "repair solder on IBM video chip" to see You Tube clips of how to re-flo IBM Video Chip.
Posted on Jan 13, 2012
    Scholar:
  • 125 Answers
Z mean sleep or power save. Try to go to the power option in the control panel and turn off all energy saving options (monitor, harddisk, computer). It this works, you can leave the setting as is or you can adjust it accordig to your preference (ie, in battery mode turn off the monitor in 15 minutes...
Posted on May 22, 2007
  • Michael Ifurung May 24, 2007
    There is a very small switch near the keyboard that is activated when you close the screen. The action of the switch is programmable in the power management utility.
    Maybe this little switch is activated when you are using the keyboard. By default, when you close the LCD the computer will go to sleep mode to prevent overheating when the LCD is closed.
    What you can do is go again to the power management utility and disable the action of this switch. You will find a text that say 'action when the LCD is closed. The options are hibernate or sleep, power off, or do nothing. Thry to set to do nothing and observe the result.
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Whilst using my computer the monitor went blank. I turned the monitor off and back on. It stayed on for less than a second before going blank again. There was power to the monitor. I left it for a few...
can u boot into the safe mode and see if the monitor will work cause it sounds like to me that you either have a driver that is failing or the monitor is failing
Aug 18, 2008 | HP Computers & Internet
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
IBM ThinkPad T42 Notebook Logo
188 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
