How to change fax ringing settings ricoh mp201 spf?
SOURCE: ricoh mp161 spf
Transmission Settings!
Posted on Sep 12, 2008
  • 86 Answers
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Posted on Jan 13, 2009
SOURCE: Ricoh 1013F Fax Line answering phone calls
"user tools", scroll to....."fax features", scroll to "setup", scroll to "no. of rings"
Set the appropriate number of rings to not conflict with Voice mail, etc...usually 4 will do, but just test the phone and fax after you set it up, to make sure it is ok. You can test it by calling it from your cell phone, or a land line (on another line), in other words, you don't have to wait for a fax, just dial the fax number and see when the fax picks up, then try the phone number etc.
Posted on Mar 09, 2009
SOURCE: Ricoh Aficio 350 change number of rings before fax answer
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Posted on Mar 25, 2009
santosj27
  • 263 Answers
SOURCE: How do I scan using a ricoh afcio mp201?
Hello!
This is a very good machine.
You can use scan-to-folder or scan-to-email.
The first step is to add users in the address book.
You have many configurations to make so i will suggest you to take a look in the user manual.
You will see everything to help you (step-by-step).
See you!
Posted on Jun 23, 2011
I have a machine ricoh mp201 with code sc391 afta changing the toner motor and developer
Development bias leak
The polling module detects a
current leak of the development
bias.
?? Loose connection of the PCU
?? Defective high voltage supply
board
Apr 13, 2017 | Ricoh Office Equipment & Supplies
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
My ricoh mp201 copier won't power up
Have you fed it with right food? Or did you check if you have faulty power cord...?
Aug 16, 2013 | Ricoh MP201 F Copier
How do I scan using OCR with Gestetner DSm520pf. (I think this machine is sold in South Africa as the Gestetner MP 161 spf) I have looked through the settings but just can't figure out how to do a scan...
It is actually sold as the same model here, and also a Ricoh AC205L. (Ricoh owns and builds all machines for Gestetner).
I don't have any real familiarity with this unit, But i know you need use the "Smarthru 4" software to use the OCR feature. You can download it from the Ricoh site here if you need to:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/ac205/ac205en.htm
Jul 16, 2009 | Office Equipment & Supplies
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
237 people viewed this question
jasbo
jasbo
