Question about Whirlpool Washing Machines
Whirlpool awm 8105 f06 - Whirlpool Washing Machines
4 Suggested Answers
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
gvince4
  • 31 Answers
SOURCE: whirlpool awm 8142 faul code
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Posted on Nov 15, 2010
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
What is that an error F06 for Wirlpool awm 1000 ex
Whirlpool's 'F06' suggests that there is a problem with the motor speed- no motion detected, sorry. Looks like a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
Hi There
  • Check the MCU
Dec 11, 2009 | Whirlpool Washing Machines
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
