Question about Maytag MSD2656G Side by Side Refrigerator
I have model # MSD2542VEB01 REFRIDGERATOR and need to know how to remove the water filter to replace it. Do I also need a new cap or can I reuse the old one.?
5 Suggested Answers
  • 363 Answers
SOURCE: AFTER REMOVING CAP, THEN WHAT? HOW DO I CHANGE
Pull the old filter out and install new one and put cap back on
Posted on Jul 24, 2009
  • 1891 Answers
SOURCE: model#MSD2542VEB01 do not know to remove front
it just snaps offfbut they do fit tight and you would think it will break before commong off. so open both doors and use a putty knife and help it off. **** hope this help's ..
Posted on Jan 19, 2010
woodchuck789
  • 4059 Answers
SOURCE: I have no way to remove the evaporator tray from
There not really made to remove. If you need to clean it, just reach where you can with a rag. Pour some bleach in it to kill any mold and fungus and soak it out with the rag.
If it has a leak, dry it out and patch it with some epoxy.
Why else would you want it out.
Posted on Feb 10, 2010
  • 5370 Answers
SOURCE: Old filter in and water
When you change your water filter you must purge the line to remove any air or it will continue to flow all over the floor use as large a container as possible it will require you to draw at least 2 gallons of water to purge air in line. -------- After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser. ----------- This will help.Thanks.Helpmech.
Posted on Sep 23, 2011
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I replace my UltraEase water filter?
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
Step 2
Step 3
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Hope this helps...
Aug 12, 2010 | Whirlpool Refrigerators
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
I have no way to remove the evaporator tray from my Maytag MSD2542VEB01 refrigirator. Cant remove from the back and the front is blocked by the water filter and water pipes.
Feb 10, 2010 | Maytag MSD2656G Side by Side Refrigerator
What is the grill cap on the PUR filter? I don't seem to have it.
HI, Is the filter down near the floor in the kick plate?
If I had a model # I caould look this up for you.
Thanks
VIc
May 30, 2009 | Refrigerators
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
I need to change the water filter on my refrigerator
Since I didn't have the service manual, I had to play around until I stumbled into a way to remove the filter. To remove the filter: 1. locate the filter (bottom front under the refrigerator door). 2. push the button next to the filter cap until the filter is released. 3 remove the fillter and take that filter to the local home supply store to make sure you have the correct match. 4. replace cap on new filter, remove inlet protecting caps on new filter, and push the filter into place.
Mar 19, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refridgerator not cold
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Nov 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't locate the filter
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Filter is at the bottom of the fridge, in the grill, 6-8" from the left side.
Manual and parts list is available at http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gs5shaxtl01&siteCd=WHRCOM
Regards,
MrBoo
5. Remove the protective covers from the O-rings. Be sure the
7. Flush the water system. See “Water and Ice Dispensers.”
gaskets. Do not use paper towels, scouring pads, or other harsh
cleaning tools.
Nov 11, 2008 | Whirlpool Refrigerators
Maytag MSD2656G Side by Side Refrigerator Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
