Question about Maytag PAV2300 Top Load Washer
Maytag washer MCS No. 22003218
Will not fill up water
SOURCE: Top loading Maytag washer Model
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Posted on Jul 16, 2008
  • 1028 Answers
SOURCE: maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Posted on Dec 13, 2008
SOURCE: Maytag washer filled with water then stopped working.
You can check the lid switches (they are paired) the following way:
1) take off the front and top washer housing panels.
2) look for the wire bundle coming off the lid switch and find the plastic pull apart connector.
3) undo the connector.
4) take an Ohm meter and check the resistance when the lid is closed: a) orange and black wires should complete a circuit, orange and pink should also complete a cicruit, all other pairs shold be "open".
5) check the resistance when the lid is open: orange and white should make a circuit, but no other pairs.
6) replace the defective switch, or replace the complete unit.
7) check the 250V 1A fuse in the left front, replace it if it has blown.
Good luck.
Posted on Dec 15, 2009
mastatech
  • 478 Answers
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Posted on Jan 10, 2010
wpcustomer
  • 408 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
    Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
    If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
    If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
    Jun 06, 2016 | Maytag Washing Machines
    I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
    Maytag & Whirlpool washer diagnostic - Fills with water then ...
    ? 3:03
    https://www.youtube.com/watch?v=71zySSScDPE
    Jul 11, 2013 - Uploaded by ApplianceVideo.com
    Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
    Maytag top loading washing machine stopped working & filled with
    Dec 02, 2015 | Maytag MAV5920E Top Load Washer
    Maytag atlantis washer water won't stop filling with water even when power is off.
    water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
    Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
    Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
    Maytag Atlantis MAV7600AWQ Washer. Delayed fill
    ALL WASHERS COME WITH SCREENS AT THE
    WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
    NEEDED AND GO FROM THERE.
    Mar 07, 2009 | Maytag MAV7600 Top Load Washer
    I have a maytag washer # LAT 9593 , washer fills with water very
    Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
    Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    Washer won't fill
    First take off the fill hoses from the washer, make sure the screens on the washer valve are not clogged. Next heck nd make sure you have water coming from the hoses. Finally if still no water. you may ned a new fill valve. Hope this helps , Dave www.washermd.com
    Dec 22, 2008 | Maytag HAV3460AWW Top Load Washer
    Maytag PAV2300 Top Load Washer Logo
    52 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
