Question about Montgomery Ward Sewing Machines
Balance wheel doesn't move needle
When I manually rotate the balance wheel, the balanace wheel will turn, however the needle does not move up and down accordingly. I have just recently taken this out of storage, and it probably hasn't been used for a few decades at the least. I've oiled all the poinant parts, however the needle doesn't seem to be engaged with the balance wheel mechanism. Any thoughts??!? I'd love to get this thing up and running! I am SOOO close!
  • Montgomery Ward Master
  • 1,564 Answers
You really should clean and oil/grease the entire thing. Dust, lint, old oil and grease can harden making your machine not run properly. Another thing that may be causing you issues is dried up and gunked up grease on some inner gears. Take off as many access panels as you can and use a tooth brush to remove yellowed dry grease from gears, replace the grease with one made for sewing machines. Lightly grease... just a little dab will do it. Turn the machine by hand to work the grease around the gears.
Make sure it's out of bobbin winding mode. Do you remember if you had had to replace the motor belt or had to take the hand wheel off for some reason?
Take the hand wheel off and look for a funny looking lock washer (typically has ears on the outside of the washer and two fingers pointing toward the center of the washer that fits into two grooves) The two fingers are slightly angled... the angled fingers should be pointing OUTWARD when you put it on. This seems counter intuitive but it must be inserted this way for your machine to work correctly. Put it back together and see if it works.
I like to use Liquid Wrench for especially stubborn machines that have been sitting. Don't use WD40 it will free up rusty things but you have to wipe it down well and re-oil. Liquid Wrench is petroleum spirits (kerosene) and graphite, much better for the machine in the long run.
Good luck.
Posted on Nov 07, 2012
  • Savanna-Jack Hennessey
    Savanna-Jack Hennessey Mar 15, 2014
    This was the most helpful thing I've found today, I had the washer in backwards. Thank you!!
  • sylviaivie Mar 16, 2014
    You are welcome. Yeah, I did that too. I've since learned to take pictures when I disassemble something. :) I love old machines and attachments, such fascinating engineering.
SOURCE: The motor runs but the needle won't go up and
It sounds like the bobbin winder is engaged. On the top of the machine on the right hand side is a spindle that you can put your bobbin on to wind it. Make sure this spindle is pushed to the left when you want to sew and pushed to the right when you want to wind a bobbin.
Posted on Oct 14, 2009
bargainbox
  • 1388 Answers
SOURCE: Sears Kenmore 1168280 (Old machine not used much)
Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
Undo the needle clamp and remove the remains of the needle.
Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
Best Wishes
bargainbox.com.au
Posted on Jun 08, 2008
  • 46 Answers
SOURCE: the bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Posted on Oct 24, 2008
  • 5603 Answers
SOURCE: I have a simplicity fashion
There is a problem in timing. Something probably has slipped in the adjustment. I would recommend you take this to a repair shop as adjusting the timing can be tricky. With no needle or bobbin the problem has to be buried fairly deep in the linkage and hardware near the selector. You might be able to observe the operation by taking the cover off and watching for what is jamming. Look at the cams that control the different stitches as the likely problem. Sometimes there is wear or breakage associated with this part of the machine.
Posted on Apr 29, 2011
  • 233 Answers
SOURCE: I've just bought a Pfaff
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
Posted on May 11, 2011
Hand wheel rotates but stop motion screw doesn't rotate and it is not moving the needle up or down
Robin. Take off the hand wheel. Look for the funny looking washer with ears. The center fingers should be angled outward when you fit it into place (counter intuitive, I know) Fit everything back together and try it again.
Oct 25, 2012 | Singer 20U73
Balance wheel doesn't turn
Don't force it. open up under the presser foot and the bobbin area.... pick out any threads.
Sep 01, 2012 | Janome L-344 Mechanical Sewing Machine
The foot pedal wont move the needle
Ok, I am assuming that you have an old style machine where the hand hand wheel has the larger balance wheel on the outside and inner knob to release the drive to the needle and feed dogs. If that has been removed and not put back together properly it won't work.
There is a special locking washer inside those that have "fingers" pointing to the inside of the circle. They must be fit into the shaft correctly before the knob is returned into place and the little screw is tightened down.
This guy is a bit of a windbag but watch his video... you'll at least see the part I'm talking about. He shows the part at about 9:50 in the video.
Aug 03, 2012 | Sewing Machines
While sewing the error message came up
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbine area for loose threads or lint
and if turning off the machine & turning it back on doesn't help
then the machine may have to be checked
Apr 11, 2012 | Brother PC-420
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
324 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
Les Morrison
Les Morrison
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
