Question about ASUS P5LD2-VM Motherboard
Computer Restart again and again - ASUS P5LD2-VM Motherboard
  • abby99 Mar 12, 2009
    Computer usually boots up fine, runs from 5 minutes to several hours and then reboots by itself for no apparent reason. Installed a new hard drive, 2 more GB of RAM, ruled out power supply and overheating.
    It will run indefinitely when booting from a Linux CD though.
    There doesn't seem to be any particular pattern and it doesn't matter what I'm working on, if anything.
    I have run every possible diagnostic that I can think of.
  • Anonymous May 02, 2009
    my computer restarts again and again while restrting CPU light glows more and then restarts
Chek your smps voltes
Posted on Mar 02, 2009
    Champion:
  • 254 Answers
Remove the cmos battery from the motherboard for at least 1 hour then replace , if it continues to reboot it may also be your hard disk or os causing it
hope this helps
Posted on Jan 05, 2009
Sir,I have changed my PC's motherboard from Intel845GVSR to Murcury PI845Z.But I have faced frequent restarts problem with error message either DRIVER_IRQL_NOT_LESS_OR_EQUAL or IRQL_NOT_LESS_OR_EQUAL.Kindly Advice
Posted on Jun 03, 2011
Set up failed after down loading files to restart
This is usually a RAM issue. The files did not read correctly. try different RAM, boot off the DVD again and try again. Usually works.
Jan 04, 2015 | Computers & Internet
My toshiba laptop u400 142 freezes .. when i restart in safe mode it works ..but no other functions works..but restart again..on restarting it does again..what a rubbish laptop i bought what shall i do sir
try to clean boot your computer.
  • on safe mode, click start > run > type msconfig
  • you have several tabs there, go on Startup tab, click on Disable All button
  • go to Service tab, it's on the right of Startup tab, put a check mark on "Hide all Microsoft services". make sure you have a check mark there. then click on Disable all button.
  • click on Ok
  • the computer will ask you if you want to restart or exit without restart, restart the computer
  • when you see your desktop after restarting, put a check mark on "Don't show this message again"
  • observe the computer if it will still freeze.
Mar 14, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
When I start computer it goes to safe mode then again restart
hi... check the Keyboard some key r stucked. hold the F8 til it going to boot
Dec 11, 2009 | Intel Pentium III , 866 MHz Processor
Ulead movie factory 6.o I cannot overcome a relink message any ideas please
Do you have the Ulead program on disk?
Go to Start>Control Panel>Add/Remove Programs, and remove Ulead. If asked to restart your computer, do so. If not, close all windows until you are back to your desktop scree, and restart your computer. (Windows XP: Start>Turn Off Computer>Restart)
After Windows boots back up again, and all your Start Menu programs, reinstall Ulead again.
Nov 03, 2009 | Computers & Internet
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
HP 1020 LaserJet Problem I can only print one job and then have to restart the computer before it will print again. The jobs are in the print que, they just won't print. When I restart the computer a...
Change the USB cable. The cable you are using isn't sending data BACK to the computer that tells the computer that the printer is ready, and you have to reset, Change the USB cable for a NEW one, and then your computer will talk to your printer and vice-versa.
Feb 16, 2009 | HP LaserJet 1020 Printer
Installed 3d ultra mini golf adventures deluxe on a PC. After launching, there is a delay, then the computer responds that it "can't find orginal disk or authenticate." The disk is in the drive. any ideas?
If you have more than 1 CD/DVD Drive, try a different one...
Otherwise restart your PC, if that still doesn't work then follow this procedure :
1 : Deinstall 2 : Restart Computer 3 : Reinstall 4 : Restart Computer 5 : Restart Computer again 6 : Try again
Jan 04, 2009 | Vivendi Universal 3D Ultra...
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
My laptop compaq armada is restarting
when the computer try to restart push the F8 key and go to the last know good config restart the computer again and see if is ok if not restart again and push the F8 and go to save mode loock for any hardware or programs the one is not ok remove it and restart that again if you can acces the hard drive and is not fix you may have to re install windows or repair it
Dec 09, 2007 | Compaq Armada E500 Notebook
ASUS P5LD2-VM Motherboard Logo
1,086 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
