Question about Canon Rebel XT / EOS 350D Digital Camera
Looking to reset to original factory settings
Reset camera to factory settings
  • ronheyse Jan 05, 2009
    under the setup2 menu i have language,video system and communication as my 3 choices i dont have a clear settings option
  • rickhogg Mar 18, 2009
    I have this same problem: "under the setup2 menu i have language,video system and communication as my 3 choices i dont have a clear settings option"
  • 2,131 Answers
On the camera's menu system, under Setup2, look for the option titled "Clear Settings". When selected, you can either clear just the Custom Settings, or you can clear all camera settings, which restores it to the factory defaults.
Posted on Jan 05, 2009
  • old marine
    old marine Jan 05, 2009
    Set the mode dial to P, Tv, Av or M. Then you should see more selection options in the Setup2 menu.
When a problem arises on your Canon 350d, Canon tech support will advise you to first reset your camera...set the mode to P and then go to menu, setup tools 2, clear settings..
the second option is to update your firmware by visiting the canon website, you can access this by going to google and searching for 350d firmware...
the third option will be to send your camera for service in Borehamwood UK...
hope this helps.
Posted on Sep 23, 2009
3 Suggested Answers
  • 11 Answers
SOURCE: Can i reset the settings to the original factory settings?
In order to reset the camera settings to its default values you need to do the following:
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
This will reset the camera to its factory default settings.
Posted on Jul 26, 2009
Steve5
  • 423 Answers
SOURCE: Reset to factory original
If you go into the "set-up" menu you should find an option which allows you to reset all the settings back to factory original.
Posted on Mar 04, 2008
Reset the date and time to original factory settings
Please follow the steps below to reset the setting to default...
1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sx200resetscreen.jpg 3. Using the arrowdownbutton.gif button, select [Reset All..] and press funcseticon.gif. sx200menudirection.jpg 4. Select [OK] and press funcseticon.gif. sx200resetconfirm.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Feb 19, 2010 | Canon PowerShot SX 200 IS Digital Camera
I installed a new cf card in my canon camera. It says "card not formatted" and when I try to format it, it says "cannot format. change CF card". what gives?
Check if you're using a compatible CF card in the Camera. You can look in the user manual of the Camera to check for the compatible CF cards.
If the CF card that you're using is compatible but not working in the Camera then try using the card in other Camera to determine if the issue is with the card.
If the Card works normally in other Camera or device then reset the Camera to the original factory settings.
Even after resetting the Camera to the original factory settings if the CF card doesn't work in the Camera then you may try using any other compatible CF card to determine if the issue is with the CF card reader in the Camera.
Oct 30, 2009 | Cameras
My sony dsc w80 is taking green pictures! It was working perfectly, but recently every pic has a green effect. Ive tried to fix it but can't figure out.
Hello!
Please turn off the Camera and pull out the Battery then press and hold the Power button for 30 seconds. Next, reinsert the Battery and turn ON the Camera then reset it to the original factory settings. Furthermore, please ensure that the Battery pack in the Camera is fully charged.
Follow the steps given below to reset the Camera to the original factory settings:
Press the Home button then select Settings, Main Settings 1 using the control button. Next, select Initialize and OK.
This will reset the Camera to the original factory settings. If the issue persists then the issue is related to the image sensor of the Camera and service will be required to get it fixed.
Aug 23, 2009 | Sony Cameras
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
No flash and screen flashes "E:91:01"
Hi!
The error E:91 indicates a hardware malfunction in the Camera. In this case, you may try resetting the Camera to the original factory settings.
(a) Press the Menu button to display the menu screen.
(b) After pressing the right arrow on the control button, go to the (setup) setting, then press the right arrow again.
(c) Next, press the left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" option OK, OK.
(e) Set the clock if date and time screen appear.
(f) Next, turn off the Camera and remove the Battery pack and press and hold the power button for 30 seconds.
(g) Then, reinsert the Battery pack and turn the Camera ON.
Performing all the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, please check the operation of the Camera.
If the Camera continues to display the error E:91 then service will be required.
Regards,
Pacific.
Aug 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Jul 14, 2009 | Canon IXUS 80 IS Digital Camera
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dsc-w40 when turn on the word access and lens goes in and out
Please remove the Battery from the Camera then reinsert it after three minutes. Please make sure that the Battery is fully charged. If menu options are accessible then reset the Camera to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings.
(i) Turn ON the Camera.
(ii) Press the Menu button on the Camera to display the menu options.
(iii) Then use the control button on the Camera to the select the Setup option.
(iv) Next, select the Setup 1 option then "Initialize".
Performing the above steps will reset the Camera to the original factory settings.
If the issue persists even after resetting the Camera to the original factory settings then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Camera problems
Go to camera Menu and select Initialize, this will Reset your camera to factory default settings.
Jan 08, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Sep 28, 2007 | Fuji FinePix V10 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
5,554 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
