Question about Life Fitness 95Te Treadmill
What size fuse dose a Life Fitness 95Te Treadmill need?
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Posted on Apr 12, 2010
bwinton
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Posted on May 07, 2010
SOURCE: I have a Life Fitness
press the speed arrow down 3 times, then the stop 3 times
Posted on Jan 05, 2011
What does activity zone keypad not detected mean
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control.
LifeFitness 95TE Treadmill Parts SPORTSMITH net
Jun 05, 2014 | Life Fitness 95te Treadmill 7 Inch Touch...
Activity zone keypad not detected
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control. LifeFitness 95TE Treadmill Parts SPORTSMITH net
Wax bag change
you need to add wax to treadmill belt lubrication system
Oct 26, 2013 | Life Fitness 95te Commercial Club...
How to access to life fitness treadmill 95te menu
Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
Oct 09, 2013 | Life Fitness 95Te Treadmill
I have a life fitness 95Te and can not reset the wax bag notification on screen. i'm told to hold the pause button then press the clear button. I don't have a CLEAR BUTTON!!
Dear Si:
Please go to the pag 48 from your user manual. If you do not have the user manual. go to the next web page: www.fitness.manualsonline.com and download for free, and follow the instruction for reset your wax bag device.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 15, 2012 | Life Fitness 95Te Treadmill 95 Te
The screen reads "Unit immobalized
Here is the manual for your unit. See the section on Managers Configuration specifically custom message on page 37.
http://jp.commercial.lifefitness.com/resources/content/4/9/7/3/documents/95Te%20Console%20User%20Manual.pdf
May 16, 2011 | Life Fitness 95Te Treadmill
Hi, I have a Life Fitness Treadmill that says "Unit immobolized by manager". Could you please tell me how I can fix this? Thanks!
hi
press clear it
then when it comes on HOLD SPEED DOWN AND press PAUSE it clears up
call me 347 515 8670 if you can not do it
Nov 20, 2010 | Life Fitness 95Te Treadmill
Life Fitness 95Te Treadmill Logo
15 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
