Question about LG WD-1280FHD Front Load Washer
Removal of the bearings
HI, I have a problem with "How to remove the Bearings" from my LG washing machine. as it is direct drive, it is not as simple as replacing a belt on a normal machine, i know my problem is the bearings, as the noise is quite loud, and to continue to use the machine would be stupid, as i have a large family, i really need to resolve this problem fast, any advice would be gratefully recieved. Thank you mrs Brown
  • 489 Answers
Those bearings are almost impossible to remove.  You would be better off replace the rear half of the tub assembly as it comes with everything.
Posted on Apr 28, 2008
  • LG Master
  • 2,471 Answers
Go to either repairclinic.com or appliancepartspros.com for how to videos on your model. they will show you how. i did it from their info and had never done anything like that before. give it a try. bearings and seals are not that expensive.
Posted on Sep 22, 2015
SOURCE:
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Washing Machine makes a groaning sound.
Its most propably bearings on the drum,normally the seal in front of the bearings is leaking ,allowing water into the bearings, which destructs them..
It is bigger job to take the drum apart but do'able with basic tools.
If possible, source the seal and bearings beforehand.
Another factor can be overloading,try lightening the loads first..
Oct 05, 2012 | LG Washing Machines
How do i remove the bearings
Hi
In a washing machine, the bearings protect the drive shaft from over rotation due to the forces applied to the washtub.
Unplug the washing machine from the power outlet. Turn off and disconnect the washer from the water pipes. Pull the machine forward so that you have easy access to the entire machine.
Unscrew the lid's top two screws and remove the machine's top panel.
Slide out the machine's back panel.
Slide off the fan belt and set it aside.
Unscrew the drive shaft's end bolt. This is the bolt that holds the pulley into position.
Remove the pulley by placing the screwdriver underneath it and gently leveraging it off.
Remove the drum's three bolts that hold its spider bracket into place. If the bolts are sticking use, rust remover and degreaser to loosen them. Do not apply too much pressure to the brackets or you will strip them.
Tap the spider joint gently with a hammer while pulling on it. The entire joint and the bearings should slide off.
Clean up the spider shaft, removing all rust and debris using cloth diapers and rust remover and degreaser solutions.
Tap the new bearings into place.
Tap the new drive shaft seal into place. The drive shaft seal should always be replaced with the bearings to ensure water-tight protection for the machinery.
Reassemble to washer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Indesit W 123 Front Load Washer
LG direct drive washing machine is getting increasingly noisy when at the spin stage
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Jul 12, 2008 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Removing the bearings from my direct drive washing machine
If you're talking about the rear drum support bearing, they are usually not removable. They are molded into the plastic tub shell. When the bearings go bad you generally have to replace the entire back shell of the wash tub.
May 22, 2007 | LG WD-1280FHD Front Load Washer
LG WD-1280FHD Front Load Washer Logo
378 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
