SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
