Question about Candy AQW130 Front Load Washer / Dryer
Candy Aquaviva 1300 washer dryer, not drying clothes.
Hi, I am looking for an instruction booklet that shows you were the thermostats and heating element is located in the back of the machine.
SOURCE: Candy Activa Smart 1300 AA
Many thanks had already done this and all is working fine now fingers crossed!
Posted on May 31, 2008
Agent Dort
  • 216 Answers
SOURCE: Instruction manual
Greetings psbrodie,
You can find a copy of your instruction manual at the following link http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=10
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jul 01, 2008
SOURCE: Will not drain
I have a similar problem with my Candy WM801. However I cannot find the filter, it does not appear to be at the front... pulled it out and can't see anything obvious at the back either. Looking online for manuals, it should be simple shouldn't it!
Posted on Sep 23, 2008
SOURCE: How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Posted on Nov 27, 2008
SOURCE: Candy CMD146 Washer/Dryer
CANDY CMD 146
when spinning the drum shakes badly and smoke comes out from soap draw , both shocks are intact at bottom and both springs look ok at each side, i dont know what else to look for please help
Posted on Mar 11, 2010
I CANNOT FIND THE LINT TRAY/HOLDER ON MY CANDY AQUAVIVA 1300 WASHER DRYER. I FIND THE DRYER GIVES THE CLOTHES A DAMP SMELL WHEN DRIED. IS THIS DUE TO LINT BUILD UP?
This is usually located either near the bottom front, possibly behind a plate, or inside the rim of the drum. Check the user manual.
May 26, 2011 | Dryers
Candy aquaviva 1300 no heat while drying
disconnect the unit from the mains supply and remove the lid you will find a thermostat with a red button on it, press this and if you hear a click, problem solved to prevent fault reoccurring always let the dryer cycle finish its self as stopping it early can cause the heater box to overheat.
regards
Ian.
Apr 17, 2011 | Candy Dryers
My candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
Sep 11, 2008 | Candy CN146 Front Load Washer
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Feb 21, 2008 | Candy AQ130 Front Load Washer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Candy AQW130 Front Load Washer / Dryer Logo
150 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
