Question about Smeg WM16AAA Front Load Washer
Need an integrated washing machine with righthand hinge
Hinge on porthole door of machine not about door furniture
How much water does a 7kg front loader use?
Depends what cycle it's used on. For example "Spin" uses no water at all.
If you want to measure it, run a cycle without laundry, and mark on a piece of paper tape stuck to the porthole how far up the water level reaches. Count how many times the machine empties and refills during your chosen wash cycle. After the final spin, close the door, and slowly refill the machine via the detergent drawer from a graduated jug or watering can, until the water level reaches the mark on the porthole. Multiply the volume poured in by the number of cycles, and there's your answer - approximately.
Feb 03, 2018 | Washing Machines
How can i find a porthole?
Please supply the machine's model number.
Aug 12, 2014 | LG Washing Machines
How to change the door hinge
Link to PART:
Bosch Washer Hinge -
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
Where can I get replacement integrated door hinges for Teknik 9060
we have a shop in stirchley birmingham that sells new and used parts for allwashing machines and tuble dryers if you go online you may be able to find a place near you or go on tecnik web and search for the part.
Jan 02, 2012 | Tecnik SLR 650 Washing Machines
Washing machine door seal replaced and door won't close
Could be you have not got the door seal fitted correctly around the front of the cabinet porthole, and make sure the retaining clamp is fitted correctly.
Mar 24, 2010 | Washing Machines
How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Dec 18, 2009 | Hoover Washing Machines
Changing door hinge position
you could try and pop off the door seal from the w/m front and reach down to see if retrieval is possible.
Jan 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Hotpoint wd63
take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Mar 04, 2007 | Hotpoint Aquarius WD63 Front Load...
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
83 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
