Question about VeriFone PINPad 1000SE Network Terminal
PINpad 1000se not working
I had installed my pin pad at my machine. It was working fine. But somehow it is not working now. Even it is not responding at Hyper terminal test. please help
When you power on the terminal, is the pin pad also powered on? If it is not powering on the pin pad, you might have an issue with the pin pad. If it is powering on and it's still not detecting it, it might but that you are using the incorrect cords or the programming is blown on the pin pad. You will have to contact your processor to see if they would be able to reprogram your pin pad if that is the case.
Posted on Jan 31, 2009
POS
Tamper message will remove through tamper removal software in 1000SE.
psoftware109@gmail.com
Mar 31, 2014 | VeriFone Pinpad 1000Se - Keypad
Plugged new pinpad 1000se into my verifone vx570 according to instructions. Pinpad shows the moving arrow to indicate it is on. When I run a debit, it does not switch over to accept the customer's pin...
The terminal has a setting to tell it whether to use the external or internal pinpad. Yours is still set for internal. Call your merchant services provider and they will change the pinpad setting so that you can use the external PP100SE.
Apr 29, 2011 | VeriFone PINPad 1000SE Network Terminal
VeriFone Pinpad 1000se - it has "Tampered Device - Press any key" error message. How do I reset this so it will work?
if the intrenal battery is bad you will also get a tamper error, battery needs to be replaced and reload or inject encryption.
Sep 21, 2010 | VeriFone PINPad 1000SE Network Terminal
Need help hooking up pin pad
Simply plug the PIN pad cable into the comm port on the back of the terminal marked with a PIN pad symbol. As far as programming, has this PIN pad been injected with the proper encryption key? If you bought it right off the shelf, you will need to send it to your payment services provider for key injection.
Jun 24, 2009 | VeriFone Omni 3700
The new pinpad 1000se doesn't work while the older version did. What is the difference? Same model #?
The pin pad needs to be encrypted by your merchant account provider. I am assuming you purchased from Online.
Call your provider and you need to send it for an encryption cannot be done over a dial or ethernet download. Once you receive the Pin Pad back make sure the power is completely off before plugging in peripherals especially Pin Pads for it will blow out that encryption.
Call me if you need clarification.
www.greenlightpayments.com ext 105
Jun 17, 2009 | VeriFone PINPad 1000SE Network Terminal
I need a Vista driver - the XP driver won't install under Vista
Check for the driver on the make and model's web site, not the windows...you should find what you are looking for.
Jun 01, 2009 | VeriFone PINPad 1000SE Network Terminal
Where can i get device driver's for NURIT 293
That pinpad does not have drivers associated with the unit. The unit will only work with a credit card terminal IE: Nurit 28xx, 30xx, 80xx and also software developed specifically for the pin pad to work. You can only use that pin pad with a 9Pin serial cable to pc.
May 07, 2009 | VeriFone PINPad 1000SE Network Terminal
Pinpad won't work, but has worked before.
The encryption that is loaded on the pin pad is wiped out; this may have happened when powering off the terminal, unplugging the pin pad without unplugging the terminal power source first. What you would have to find out is what platform you are on from your processor, if they are not willing to do it, you can contact companies that will reprogram your pin pad. This will be cheaper than to buy another pin pad.
Dec 12, 2008 | VeriFone PINPad 1000SE Network Terminal
Microsoft Retail managment system
You need to have the correct keys loaded into the pinpad. If you got the pinpad from some place other than from your processor, you are out of luck. They will only load the keys when the pinpad is physically in their possession.
Feb 29, 2008 | VeriFone PINPad 1000SE Network Terminal
VeriFone PINPad 1000SE Network Terminal Logo
1,327 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
