Question about Watches
Set clock smartek ce - Watches
2 Suggested Answers
male_28_cam
  • 1555 Answers
SOURCE: how do I set my
Kindly let me know how many buttons does it have on right and left side. Then only a precise solution can be provided.
Posted on Mar 08, 2011
How do I set the time on my Polar ce 0537
Hi Terry ,
there are lots of instruction video's U Tube
https://www.youtube.com/watch?v=Q8XzaXs_Pz4
this should help you in setting your watch.
Sep 08, 2017 | Polar Watches
Set the clock on the zip931 electronic microwave oven
The procedure is rather non-intuitive, as you have to press CANCEL to set the clock.
From the ZIP931 manual:
Setting the Clock
1. Touch CLOCK
2. Touch CANCEL
3. Enter the time
4. Touch CLOCK again
Note that this microwave oven is also sold under Asda, Russell Hobbs, and Oriental Pacific brands
http://www.fixya.com/support/t5816263-set_clock
http://mda.russellhobbs.com/IBS/RHM2016.pdf
May 24, 2013 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    I need a new watch band for my Nixon Scout watch
    Try contacting a Nixon service center.
    You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
    Mar 02, 2010 | Watches
    Settiongs for Weather Data World Clock
    Citizen Weather Data Clock Settings.
    To set time press and hold for 5sec "set" button
    Use advance to add days, years, hours seconds.
    Press SET to hold.
    Oct 17, 2009 | Citizen Watches
    Set time on Touch Screen Thermo Clock
    Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
    1. To set the time, touch the clock icon on the upper left corner;
    2. Keep touching the screen for longer than 5 seconds, on the hour area;
    3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
    4. Touch the clock icon again to start the clock;
    5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
    6. To set the date, tocuh the calendar icon on the left hand side;
    7. Keep touching the screen for longer than 5 seconds, on the year area;
    8. Touch the year area until you get what you want;
    9. Touch the month area until you get what you want;
    10. Touch the day area until you get what you want;
    11. The screen will reverse to the time display after 5 seconds if no touch.
    12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
    P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
    Hope it helped.
    May 08, 2009 | Watches
    Wacky wake up alarm clock instructions
    Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
    Jan 03, 2009 | Watches
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
