Question about Ryobi Garden
Ryobi RBV26 petrol blower will not prime?
Although reservoir half full, seven pushes (and more) fail to suck fuel into viewing bulb. The blower was a gift on last Fathers' Day and I successfully used the blower function shortly afterwards, but not since. With Autumn upon us and "a small silver birch tree forest" in the garden I really need it to be working.. Any help will be greatly appreciated. Regards Ted Knopp.
trippssmengi
  • 76 Answers
SOURCE: My tro bilt model tb320bv gas leaf blower will not run at full th
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Posted on Jan 14, 2009
  • 36 Answers
SOURCE: Ryobi RBL30MVA petrol blower problem
if this is a brand new I would ask is the gas oil mixture fresh and of the proper ratio. most use 40-1
if this is not brand new look and see if the muffler could be clogged up. a common problem is the spark arrestor screen gets clogged up with carbon deposits.
Posted on Mar 11, 2009
  • 35 Answers
SOURCE: Featherlite will not start
first never let any one browe your tools or your wife thay could break eather of them noe get a small screwdriver find the air adjutment screw on carb turn it in count the turns till it stops then pull it out by turning it counter clock wise dont louse any spring that might be there its out get carburator chock cleaner use the little tube put it in hole were the screw lived at and let it have a good blast or 2take out spark plug and pullthr start rope 10 or 15 times put plug back put air screw back 1 3/4 out from bouttom i think if you had dif number try it first if that dont fix it you may need to take carburator off take it apart and clean there is two gas lines that go to tank if one of the lines has a filter on it inside the tank if thay get water in there threeeere pluged up might get new one there fun to get out of tank or take to shop if you dont have all the tools or homedepo and buy good luck
Posted on Apr 09, 2009
  • 246 Answers
SOURCE: Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
bbreton
  • 437 Answers
SOURCE: PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Posted on Nov 11, 2009
Why won't my chainsaw prime?
if no gas will enter priming bulb at all I see only a few possible things for this
(1) gas line broken/melted
(2) filter looks good but has internal plug
(3) primer bulb has a small crack in it (most common )
Apr 30, 2015 | Ryobi RCS3535CA Petrol Chainsaw 35cc...
How do I replace the petrol primer bubble
simple !! just obtain a Ryobi fuel system repair kit (any Ryobi dealer ) , this includes a new primer button , unscrew two Phillips screws holding clamp ring down around bubble (save them) remove damaged bubble (all of it, sometimes leaves behind bits of it) install new bubble and verify it's down in groove , reinstall clamp ring and screws , fill fuel tank and prime button (pushing it )
Apr 20, 2015 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Ryobi Weed Wasp starts but cuts out after 2 to 3 seconds.
Sounds like it is running on the prime. Check the fuel filter in the tank and if it looks clogged or dark, replace it. If that is not it, now is the time to consider a carburetor clean and rebuild, with a replacement of fuel lines and primer bulb. Today's ethenol in gas is murder on small engine soft components.
Sep 14, 2011 | Ryobi Garden
Will not prime. Typical starting procedure is pump 7 times, It will pump 2 or 3 times and no fuel will fill into bulb and then the rubber bulb gets stuck in the pushed in position. The blower is only 6...
Always fully empty any small petrol engine like that if it is going to lay idle for more than a few weeks, the petrol evaporates and leaves a scum in the carb. Did you check to see if the "bulb" is compramised or the seal around it, that may be letting in air and not creating a suction
Dec 15, 2010 | Garden
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI RBL-30MVA 30cc when pressing the primer bulb to allow petrol thro, nothing happens? and as its not letting the petrol thro, the leaf blower will not start....any suggestions? thanks ben.
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Oct 08, 2009 | Ryobi Garden
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
129 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
