Question about 2wire (1000-400108-001) Router
Wireless connection to the 2 Wire modem
We just bought a new laptop and it sees the 2Wire modem with the 802.11b card but when I try to select the 2Wire I am asked for the encription code to connect. Where can this be found.
  • mmcpharlin Jan 05, 2009
    Thank You, my notebook will now connect to the 2 Wire modem in wireless mode.
    Daniel McPharlin
  • eecom May 11, 2010
    Is this page any help to you?
    http://support.2wire.com/?page=view&...=
    If this applies to your router, it suggests there is a label on your router with the default encryption key. If you have changed it, login to your router as shown and check your settings (see the last screenshot on the page.) Your encryption code should be labelled 'key' under 'Wireless Security'? Please come back to Fixya if this doesn't help.
Hi
Most of the 2wire gateways have the WEP key or the encryption code on the bottom of it. It would a 10 digit Number of a Five Character one within square brackets.
Other wise you can go to the gateway page by accessing http://192.168.1.1 on another system which is already going online using the gateway or wired to it and in the gateway page under wireless you would find the WEP key incase the default key on the bottom of the 2wire does not work.
Do reply incase this has resolved your issue or you need more help.
Thank you
Rakesh
Expert in Dell Laptop.
Posted on Jan 05, 2009
I have a 2wire modem from att. i made a 50 foot eathernet cord, i have a eathernet transmitter teaster to test the cable to see if it is good (and it is) but i still cant get internet on the other side of...
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
Jun 24, 2010 | 2wire (1000-000057-000) Modem
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Ijust bought an laptop and when I try to connect to the wireless network,"2wire657" it ask me for a security key or passphrase where do I find this
You can find this on the two wire modem where it say WEP key right by the serial number on your 2wire modem thanks
Jun 14, 2009 | 2wire 2700HG-B Router (2700HGB)
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Just bought a 2Wire Gateway, router/modem.
Try contacting your internet provider for set up instructions.its probably a configuration problem.RICHARDM69
Dec 01, 2008 | 2wire (1000-400108-001) Router
Can i download the software for setting up my modem?
The only time you really need software to set up the 2wire is if you are going to the use the USB ports on the back of the 2wire. The 1000 series have wireless capabilities. Since you have a new laptop, it should have wireless capabilities.By default your network name should be 2wireXXX and the XXX is the last three of your SN. The network key for the 2wire is the 10 digit number that is in brackets
Hope this helps you
Oct 23, 2008 | 2wire 1800HG Router (RG1800HG00)
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
2wire (1000-400108-001) Router Logo
541 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
