All lights keep blinking
Got back from work yesterday and my printer lights were all blinking. I tried to turn it off but it wouldn't work that way. Only way to turn it off is unplugging the whole unit. The buttons are all not responding. How can I fix this problem, have never had any problems with this printer. Greg My HP 2410 all in one printer lights keep on blnking so can't print anything. I installed driver detective and removed all pirnt queues, still not working. Help. Removed color cartridge and replaced as directed by printer. Still didn't work. I also moved printer port to another location on my laptop.Disconnected, then connected printer to pc. Still did not work.
  • 139 Answers
The printer has gone bad and you need to send the laptop to the service center
Posted on Jan 08, 2009
What happens when the set wount turn on and the timer just keep blinking
the lamp needs replacement it blown replace it and reset timer the telly will be fine
Jul 05, 2013 | Televison & Video
Set the dishwasher to run while at work yesterday. Came home to find the dishwasher had water at the bottom of it that didn't drain--had plugged drain. It appeared the cycle was complete as the...
Sounds like my Kenmore when I had problems with the computer control module. I had to remove the circuit board and resolder some wires.
May 12, 2011 | Dishwashers
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer light keeps blinking after being pluged in
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Apr 08, 2009 | Lexmark X6150 All-In-One InkJet Printer
Printer dos not work !
I would take it right back and exchange it
Mar 15, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Anti theif light is blinking fast & it wouldn t
OOPS dealer only ,Try opening and closing door lock three times drivers side 10 sec interval between clicks then try starting if no go then dealer only
Mar 14, 2009 | 2000 Ford Windstar
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
I would try some simply things first. 1. Pull the power plug and wait for approximately 15 to 20 minutes before plugging back into outlet. 2. If your power plug is plugged in a power strip then try pluggin directly into the wall outlet. 3. I would make sure there are no paper jams. 4. If you recently installed ink cartridges, then check to make sure they are the right make and model for your printer. Comments: If you had a power surge the printer may just need to be powered off for awhile. Some printers will hold there settings for at least 15 minutes.
Aug 18, 2007 | HP Officejet 5510 All-In-One Thermal...
Computers & Internet Logo
David Payne
David Payne
