Question about Panasonic TH-50PV30 50 in. Plasma Television
10 light flashing error with plasma?
Hi, Got a Panasonic Viera TH42PZ700 42" Plasma. Was watching it earlier and it went off! Now in standby mode with the red light flashing 10 times, then going off then flashing again. Can some body please help me????
  • 6 more comments
  • boozy_b Jan 05, 2009
    Thanks for the reply,
    Thanks for the reply, I tried what you said but it hasnt solved the problem. It is clicking now when we turn it on so its trying to start up which is and improvement but it is still going to stand by mode and flashing 10 times. Please please help!
    Ive tried that and it still doesnt work, tried to start it up with out anything plugged in to it sky etc still wont work!
    Im running backwards and forwards tv/pc trying everything but computer says no!!! Any more suggestions please?
    is it possible it over heated, we were watching the telly and it just went off to stand by mode cant understand whats caused it?
    will try it now, be back in 2 hours!!!!
    Thanks for that Dan, Just trying it with a fan at moment told to leave it run for 2 hours with fan blowing underneath. Will let you know, keep fingers crossed!
    Ive tried everything going at it with fan at moment and keeping everything crossed that will work! Been on this mission since 9.30 this morning and I have to say ive had the most help from urselves thank you v much.
    Scholar:
  • 142 Answers
Dear sir
when u perchase is u got a menual chek last 3 page of english part there he spacify it how u set setting for frequency and also chek remote control menual it';s help u...:)
thnaks
please vote
jo_Chinmay
Posted on Jan 05, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Its the fault in the internal board due to over voltage passed to the board.and needs reparing on the particular component which is causing this .just check out the component with a meter if you have a technical knowledge.or it needs a repair technician at your place.
    President:
  • 846 Answers
There is nothing in the manual about error codes. The power supplies might need to be looked at by a repair shop. If the problem isn't overheating, thats the only thing that would cause it to just turn off other than a more severe problem that would also only be repairable by a professional.
I hope this will help you. Drop me a comment if you still have problems. I will help you.Your vote is highly be appreciated
  • Quickfx PC Repair Jan 05, 2009
    Well if letting it cool off for a few hours does work its a heating issue and might want to think about placement. If it STILL doesn't work after trying you may want to contact Panasonic CLICK HERE
    (link to there support by email page) or you can call toll free By phone: 1-800-211-PANA (7262) . If its under warranty they will be able to fix it or replace it. Otherwise you will have to pay them to work on it, find out how much it will cost and compare that to the cost of a new TV.
    President:
  • 2,110 Answers
Hi Guys, looks like, it is a thermal shutdown issue. Try the following: Keep a fan and direct the air towards the bottom vent holes. Switch on the TV. Keep it on continuously for more than 2 hours and see if the TV shuts off again. If not, then it confirms Thermal shutdown. Check if you have kep any papers, cloth etc very close to TV. Keep the TV ventilated. Let there be air circulation.
    Genius:
  • 1,913 Answers
Press power burron for 10 seconds.
then remove all connection from tv.
also reset your tv \settigns to factory defaults.
  • 679 Answers
Unplug your tv for a long time like for 5 hrs and then check again.
Thanks for using FixYa
  • 1 more comment
  • rockfixya
    rockfixya Jan 05, 2009
    might be problem is in some diode; need a service.
    Thanks again
  • rockfixya
    try to check diods by using a multimeter.
  • rockfixya
    rockfixya Jan 07, 2009
    did any solution works for u.
    Thanks for using FixYa.
  • Panasonic Master
  • 19,396 Answers
10 blinks is a fault on digital board related to HDMI signal circuit. Try moving HDMI cable to a different plug.
  • 2 more comments
  • Ginko
    Ginko Jan 05, 2009
    You get 10 flashes on panasonic plasma when the TV has a problem with the HDMI digital inputs.
    Common solutions are using a different HDMI port.
    Unplugging everything from power, and powering TV back on before HDMI connected devices, using different connections etc.
    See a discussion about same problem here.
  • Ginko
    Ginko Jan 05, 2009
    To explain the problem in more details, TV returns 10 blinks when a too high voltage gets to CPU from video input signal.
    Below there is the technical explanation for the problem, from service manual:
    "Under normal condition, pin 114 of the main CPU (IC1100) is low. When a short circuit or an over-voltage condition occurs, the SOS detect circuit is triggered causing pin 114 to go high. When pin 114 goes high, the TV shuts down and the power LED blinks 10 times.When the F+STB15V line is shorted, the base of Q3503 goes low turning it on. When Q3503 is on, a high is applied to pin 114 of IC1100 triggering the shutdown operation.The same will happen if a short circuit develops in the DTV9V line and the SUB5V line.The transistor Q3505 monitors the SUB5V and the DTV9V lines. If any of these supply voltages becomes excessive, the inline zener diode (D3505 or D3506) goes into conduction and turns on transistor Q3505. As a result, a voltage drop appears at the base of Q3503, causing it to turn on and output a high to pin 114 of the MPU, IC1100. The MPU shuts down the unit."
    The info above is more useful for a technician.
    Before calling a technician, try playing with HDMI connections, by switching connections, and uunplugging devices as suggested above.
    If that still does not work, then there is an internal fault, in that case call the service number listed on the service manual.
    The most likely is a problem with HDMI cable, as reported on many forums. Try first all suggestions on my previous comment.
  • Ginko
    Ginko Jan 05, 2009
    10 times flashing is not overheating, it is overvoltage, this can happen because of the HDMI cable or because of an internal fault, in this case call the technician.
    First leave TV unplugged overnight, and restart tv with no hdmi or other cables.
    If you still have ten blinks, then there is an internal fault, and several components must be tested and eventually replaced.
    (10 blinks= "F+15V, DTV9V, SUB5V SOS Detect Circuit" That means voltage too high (+-.5 allowed) either on 15V, 5V, 9V circuits.)
  • Ginko
    Ginko Jan 05, 2009
    The thermal shutdown issue comment is rather incorrect, and was taken from a comment for a different situation, you can try the fan, this wont make any harm, but if the TV restarts is only because it had stayed umplugged for a while.
    If it keeps having 10 blinks, voltage on internal boards is unstable.
    Here is the reference,http://www.fixya.com/support/t214778-pan...
No power to set no led lights blinking
Could be an open internal fuse or power supply failure
Sep 06, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic plasma tv indicator light blinks 10 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 12, 2014 | Panasonic Viera TC-P58S1 58 in. Plasma...
Panasonic Plasma standby button flashes 11 times
11 blinks Fan SOS PB Board. 11 blinks of standby light to Panasonic Plasma indicates a fan trouble. Check it. If you want to know more, check this link.
Jan 12, 2013 | Panasonic VIERA TH-42PR10 42 in. Plasma TV
Panasonic viera th-p42g10a plasma tv has flashing red led light
The number of flashes is indicating a specific error. If you let me know how many times the light is blinking I will let you know whats most likliy causeing the issue. Reply to this same post for assistance.
Nov 09, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma th42pz85u blinking light 10 times
This is the error code, indicating a failure inside the board. Might need attention by a qualified service technician.
Jul 30, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic TH-50PV30 50 in. Plasma Television Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
