Sansa fuze radio will not work red speaker showing
This is the second player in two weeks everything works other than the radio. It was working fine then just stoped and now shows a red speaker.
  • 1 more comment
  • Anonymous Jan 06, 2009
    Same issue.. but sometimes it does work.. but then it doesn't.
  • Anonymous Jan 16, 2009
    My Fuze radio when I first opened it, but the next day it stopped working.
  • Anonymous Jan 21, 2009
    I have the same problem. I do know that pressing the >|| (pause/play) button will make the red speaker go away (I think it's muted), but my radio will not work consistently even when the red speaker isn't showing. Help!
Shrbear, I tried your solution while my Fuze was turned on and in radio mode, and seemingly magically the radio started playing again right away. Thank you a million times over for posting this solution.....I had been without my radio for months and had wrongly assumed it was broken (funny, I had never noticed the red speaker before, which is an indication of mute ...... probably never noticed it because the volume indicator would move when I would turn the thumbwheel). Thanks again.
Posted on Oct 15, 2009
  • marcssubs Oct 15, 2009
    There is an easier and more direct solution:
    Simply hit the play/pause button while in radio mode. Apparently the play/pause button acts as a mute/unmute button while in Radio mode.
I had the same problem and I found a solution. Turn your mp3 player off and place it face down on a hard surface. place down on the back of the mp3 where the function buttons are and press down firmly. I believe this unlocks the radio. Turn the mp3 player back on and go to the radio. The volume should work now.
Posted on Oct 02, 2009
My sansa fuze is acting up
I m unable to charge my mp3 player. I have conneccted it to the computer on 4 diffrent times and it wont charge. what is the problem?
Nov 03, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze keeps freezing
Start the sansa updater, set sansa to recovery mode plug into computer. unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Also you can Try
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Nov 02, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze froze, then shut off and now will not turn back on, what do I do?
try holding the power button up for about 20 seconds and it should reset it and then it should work just fine again
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuse radio does not work
is the little speaker icon red? pless the play/pause button. It mutes the radio.
Sep 10, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Mar 15, 2009 | SanDisk Sansa Fuze MP3 Player
Sandisk sansa fuze mp3 4GB* (red) won't work right
we just got a sansa fuze and downloaded media player but its put everything photos and music from my husbands computer on to it, its for my son how do we remove it all? HELP!
Feb 20, 2009 | Audio Players & Recorders
My Sansa Fuze seems to be frozen.I can't scroll or anything.
Hold the power button up for ten seconds. The Fuze should turn off then you can just start it back up and everything should work fine!
Dec 06, 2008 | SanDisk Sansa e260 MP3 Player
My sandisk sansa fuze is freezing up is that normal?
Yes, it sounds like its faulty, even if its not, why take the chance when you can just return it. Depending on where you got it, you should be able to return it for a swap. Just make sure you have your receipt. Most places will require that you have it.
Nov 18, 2008 | SanDisk Sansa Fuze MP3 Player
1,026 people viewed this question
 Grubhead
Grubhead
