Question about Canon EOS 450D Digital Camera
Problem import picts via sd cardreader (taken with eos 450d)
I have Eos 450D (firmware 1.0.9) and sandisk ultra II 4gb card
am using windows xp
when im importing the pictures via the camera to the pc (with eos utility), it works fine
if i try to use the integrated card reader in the pc it gives an device error message (no access to the card), if i try to use an usbcardreader, it doesnt recognize the card reader at all.
how can i use the card readers with the cards (with eos45d picts taken)? the card readers both on pc and usb work just fine with other cards / other cards from other cameras
thanks for the advice in advance!
  • Anonymous Jan 05, 2009
    Exactly the same problem...!!!!
  • zhilaz May 11, 2010
    Does your integrated card reader (or USB card reader) support SDHC cards (High Capacity SD?
  • 4 Answers
Some card readers struggle with high capacity (SD-HC) cards and indeed some older devices.
If you (or a friend) has a lower capacity card (less than 2GB) try that in you camera and then pc.
You can purchase a VERY cheap USB card reader (c.£10 max) and it should sort your problem - I hope!
Posted on Jan 05, 2009
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Jul 26, 2014 | Canon EOS 450D Digital Camera
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
How do i unprotect my memory card from a canon 450d?
Thanks for using Fixya.
Every SD card should have a write protect switch located on the right edge, about 5mm from the top of the card. In order to unlock the card, slide the switch upwards.
Note that with Mini SD and Micro SD (Transflash) these switches are not present. The card is always unlocked. A switch may however be present on an SD card adapter.
Because of the position of the switch they can often be switched accidentally on inserting or removing the card.
Rating the solution is highly appreciated.
Apr 14, 2010 | Canon EOS 450D Digital Camera
How to update firmware via cable?
The explaination is on the Canon firmware download page. http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html
Basically it is done via the EOS Utillity that comes with the camera.
There, click the [Camera settings / Remote shooting] button and then the Tools symbol.
Dec 22, 2009 | Canon EOS 450D Digital Camera
Card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Nov 25, 2009 | Canon EOS 450D Digital Camera
When I put numerous SanDisk SD Cads in my 450D it does not read them. What do i do ??
Are you trying to get your camera to read cards with pictures taken on a different camera? It doesn't work that way. If you're just trying to take pictures with the cards, just format them in the camera to initialize them. This will erase them so download any pictures first using a separate card reader if necessary.
Oct 16, 2009 | Canon EOS 450D Digital Camera
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Oct 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CAN'T USE CAMERA
There is a small switch on the sd card. This can "write protect" the card so that you don't mistakenly write over something important. Move the switch to the unlocked position. If you need further assistance please let me know. also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Apr 20, 2009 | Canon Cameras
SD card not registering
use only the specified or recommended cf cards, I know ultra fast is not compatible to digicam two or more years older models.
Oct 10, 2007 | Canon EOS-1Ds Mark II Digital Camera
Canon EOS 450D  Digital Camera Logo
167 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
