Question about Vivitar ViviCam 3740 Digital Camera
Camera won't switch on.
My camera was working fine fine all along but now it won't switch on. I have replaced batteries with brand new ones, tried my rechargeables after fully charging them, but still it won't switch on. I have tried cleaning the contacts but still it won't work. When I press the Power button both the power LED and the LCD flicker for a fraction of a second and that's it. Any idea what could be causing this. I really like this camera and can't afford another one.
  • holtyaspi Nov 29, 2008
    worked perfectly until needed new batteries now wont switch on until then been a good little camera anybody help
  • Anonymous Feb 24, 2009
    Yes i had the same problem but i bought mine off of eBay. It did it as soon as tried turning it on.
    Scholar:
  • 125 Answers
Did you also try to clean the contacts of the battery on the the far end ?
Posted on May 22, 2007
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
I have a canon camera and it wont turn on i bought brand new battries for it and still nothing!
Sep 28, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Jun 13, 2011 | Nikon Coolpix S3000 Digital Camera
My camera won't turn on...it is brand new
Brand new as in you just opened it out of the box? If thats the case you have to charge the re-chargeable battery first, then put it in the camera and it should work fine. Try giving the battery a charge first if you haven't already.
May 21, 2011 | Polaroid i1237 Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
Beeping camera
Mine did the same thing for forever and was brand spankin new... When the batteries go dead once, I guess it glitches... You can put brand new ones in and it will Still say low battery or act like it anyway. Give it some time. Then try to turn it on again and it will be fine. Also it will say you have a low battery if you are taking too many pics at a time... like snap snap snap and it will shut down... turn it back on in twenty minutes and its fine... full battery. If you can't deal with this... Get a battery charger and rechargable batteries. I am using them now with none of these problems
Jul 07, 2008 | Samsung Digimax S730 Digital Camera
Memory stick error
This is a problem with the battery connector inside the camera. It is common to the DSC F717 and this camera. It's, unfortunately, a pro camera repair issue on the 828. It can be fixed DIY on the 717. I did it to mine and now it works fine.
Dec 13, 2007 | Sony Cyber-Shot DSC-F828 Digital Camera
Vivitar ViviCam 3740 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
