Luz laranja piscando 4 vezes canon pixma ip 1900
Ao ligar a impressora a os leds amarelo pisca quatro vezes
Grundig t51546
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Translation option is there.
Nov 03, 2013 | Televison & Video
Modelo da impressora,HP laserJet M1120 MFP defeito... ao ligar a impressora no display aparece ..ERRO SCANNER 22..e nao scannea a imagem..... demais funcoes como impressao,aparentemente OK!
little bit I under stood your language, there is scanner error 22, remove flat bed glass, remove scan head, check mechanism observe any breakage, replace it mechanism, if no replace entire scanner head..see the test shot.
Sep 09, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I have a Hannspree LCD TV Model HSG1113, the big yellow transformer on the power board has burnt (2cm area) the PCB underneath it. There's a type of fuse (f901) T4AL 250 V that's blown. How can...
eu tenho um lcd ke o comando a distancia nao funciona e o led pisca a laranja mas o mesmo comando noutro lcd funciona o ke tenho ke faser
Jun 11, 2011 | Televison & Video
Procuro soluçao para o erro 510 da impressora Canon Pixma MP160
reintalalo de nuevo configuralo y si no tiene le dvd de lo driver entra a dell.com y ahy va poder encontrar lo driver que busca
Oct 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to remove cartridge MOdel: Canon pixma 1900
how do i remove an ink cartridge from my canon pixma ip 1900
Jun 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My printer won't work on my new computer
gostaria de receber por E-mail os numeros padrão para regular a cor da Impressora pois foi alterada e o amarelo não aparece não estou conceguindo colocar!
por favor:
mande por E-mail:
o numero do preto:
do amarelo:
do vermelho:
e do azul:
para que eu passa regular
desde de ja: obrigado
Jan 01, 2009 | Lexmark JetPrinter Z515 InkJet Printer
Sharp al 1000
pressione a letra C então abotoam a densidade então C e abotoam Desnsity simultaneamente. A tela sairá. Incorpore 24 e pressione o COMEçO. Incorpore 07 e pressione o COMEçO outra vez. E você é todo ajustou-se.
Presiona letra C densidad C densidad, la pantalla se apaga. Entra a 24 y presiona START. Entra a 07. Presiona Start
Nov 17, 2008 | Sharp AL 1631 Copier
HP PSC 1510
Usually in the instruction book or under "help" when you open your Printer under Control panel /Printer Properties there is a section that deal in flashing lights on the printer.
This will help in finding out what area the real problem is in...sounds like a paper jam or feed problem.
Oct 04, 2007 | HP PSC 1510 All-In-One InkJet Printer
455 people viewed this question
jasbo
jasbo
