Unlock polaroid dvd player
Polaroid PODVDHD dvd upscale player
5 Suggested Answers
SOURCE: Wharfedale DS-A243 HDMI Upscaler wont play HD DVD
Hi, sorry to have break it to you but your self diagnosis was correct! It is a 'normal' DVD player that upscales and will NOT play HD discs.
Posted on Dec 03, 2008
SOURCE: locked
hold down the button in the middle and at the same time, pull up on the screen
Posted on Jan 05, 2009
bob_computer
  • 3153 Answers
SOURCE: I want to unlock my Wharfedale DS-A423 Upscaling
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Posted on Nov 06, 2009
SOURCE: LG DV490H SLIM 1080P UPSCALING
need a list of area codes
Posted on May 17, 2011
HD image format, is it possible?
Hi.
Yes, it is possible but it is not worth, and the result will not be true HD.
To get HD format you need to go through a process called upscaling. This can be done connecting the DVD player output to an upscaling device, similar to the ones that are commonly used for game consoles.
The result will be a standard definition picture where each point is traduced into 4 or more points in the HD output.
In no way you can get true HD out of a DVD, simply because the smaller points with the higher definition do not exist in the original DVD.
The upscaling device will cost from $30 to $80, and the result will not be true high definition. Considering that today you can buy a basic BRD player from about $80, buying an upscaler is definitively not worth.
This is a better solution, true HD and built in upscaling for your old DVD: Sony BDP-S360
Regards.
Ginko.
Nov 05, 2010 | SVA-USA DP262 DVD Player
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Apr 28, 2017 | Polaroid FLM-2632 Television
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Nov 12, 2008 | Wharfedale DVD-M3 DVD Player
Locked
Sep 15, 2008 | Polaroid PDM-0723 Portable DVD Player
Does not play multichannel audio (5.1) input through optical digital audio
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
smeags.
Jan 06, 2008 | Panasonic SC-HT920 System
Sd370e dvd player
the dvd player does not actually play hd dvds just upscales normal ones
Nov 29, 2007 | Toshiba SD370E DVD Player
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
