Question about Ovens
How to stop jenn air oven w256w beeping f3
After a power outage my oven keeps beeping. the oven display reads F3. when I turn the oven on it stops for a while but comes back.
eagle338
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
fridgetech
  • 473 Answers
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Posted on Jul 15, 2008
docjohn174
  • 943 Answers
SOURCE: Jenn Air Code F3 continuous beeping
HI thanks for your question.. code F3 says to replace the oven sensor ,located in the oven. top left corner. replace the oven sensor. thanks the appliance doc. please rate my answer .
Posted on Oct 09, 2008
  • 217 Answers
SOURCE: f3, f1 error mesage on magic chef stove, oven not working
http://www.applianceblog.com/mainforums/showthread.php?t=7643 click this link
Posted on Nov 30, 2008
  • 530 Answers
SOURCE: F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Posted on Jan 04, 2009
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
F3 displayed and won't stop beeping
F3 in most machines is an indicator of a faulty/shorted oven sensor. Disconnect the sensor quick connect and it should Ohm out to around 1100 ohms. Check fro continuity between each wire to frame. If you get a reading your pesky sensor has shorted to frame. Replace that ****** and party on!
8cb36f7.jpgGet yer popcorn ready for the Checking the sensor Movie:
Oct 08, 2010 | Ovens
I have a Jenn Air Oven that quit working. It
HI - The code described, F3 then F2 both correspond with indicated failure of the temperature sensor. This is a fairly inexpensive part and is easy to replace. The normal resistance of the sensor is 1000-1100ohms. Worth fixing for sure. Complete model number from tag on unit will be needed to get correct part. Let me know if this info helps- have more if needed- Thanks-  Ed
Mar 16, 2010 | Jenn-Air Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jun 22, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
