Xerox 7435 leaving black marks on paper - Office Equipment & Supplies
dekinstoke
  • 96 Answers
SOURCE: printer leaving smear marks on paper
Are you using genuine Canon ink carts?? The cheaper "pattern" carts often use lower grade inks that don't dry as quick.
Also try feeding two or three blank sheets through the printer to clean the rollers and guides.
Posted on Jan 01, 2009
  • 30 Answers
SOURCE: Black streaks through pages
There can be some reasons:
1. The Fuser is too cold, so toner was not fixed
2. Image Transfer Belt is defect or dirty
Greetings from Germany
Posted on Mar 20, 2009
  • 114 Answers
SOURCE: Willl not feed 4X6 photo paper it jams up and
try feeding the paper in one sheet at a time.
Posted on Sep 14, 2009
  • 2072 Answers
SOURCE: Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Posted on Mar 31, 2010
SOURCE: wath is default username and
Email id username deffrent
Posted on Feb 07, 2011
Xerox 7435 machin error 041340 plz advice for solutions
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Oct 25, 2016 | Xerox Workcentre 7435 Color Multifunction...
Xerox 7435 printing spot on paper
Spots on the page in a regular pattern are usually due to a problem on that colour drum or on the IBT black transfer belt.
more investigation needed.
good luck..
Jun 04, 2015 | Xerox Office Equipment & Supplies
How do I solve wc 7435 error 010-338?
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Xerox WorkCentre 7425 7428 7435 Second...
Xerox 7435, got from company who pulled out the hard drive, so I am missing hard drive and the OS, how can I get in going?What type of hardrive do I need?
Hi Arthur
Look at the cable that would connect to the hard drive.
The Data side is either SCSI, or ATA or SATA.
Look these up on Google and see what matches.
All modern Hard Drives are 3.5" for desktop computers or 2.5" for laptops. Visit a site such as OWC (Other World Computing) to purchase a drive.
Only Xerox would have the OS unless you know where there is an old copy.
Check out
https://www.google.com.au/?gws_rd=ssl#q=xerox+7435+specs
Sep 09, 2014 | Xerox Workcentre 7435 Color Multifunction...
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
How do i reset r6,r7,r8 on xerox 7435
R6-7: Go to consumable tab on your printer.
Select the R6 or R7, select reset counter.
R8: You're not able to reset it
Mar 12, 2013 | Cameras
Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
Jun 04, 2009 | Xerox WorkCentre M-24 Color Copier
73 people viewed this question
jasbo
jasbo
