Question about Stoves 1100DFSID Kitchen Range
Smashed the door glass on stoves precision 1100 serial number 40705038
When moving our cooker to our new house they picked the cooker up by the handle on the front of the oven and the outer glass has shattered on bth sides
SOURCE: Stove model as above
look on espare they list many parts and glass panels for stoves cookers
Posted on May 21, 2009
dmftrucker
  • 1922 Answers
SOURCE: I need a replacement glass oven door as ours
get this at appliance parts pros 1-877-477-7278
Posted on Nov 04, 2009
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I cleaned the cooker the
Sorry to read about your problem, I hope this helps you out.
Try and rest your circuit breakers.keep off for 5 secs
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 24, 2010
SOURCE: stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Posted on Apr 02, 2011
Can you e mail me the manual for Stoves precision 1100 cooker
no
go google and type in--- user manual for stoves precision 1100 cooker --- and download the pdf version your self
Sep 26, 2016 | Stoves Ovens
I have stoves es 550 new home cooker and have broken glass on outside of oven door can l get a replacement door and if so where.
Try a company called INTERSPARES
01526 322540. they will need model & serial no.
they also have a web site and are reasonably priced.
I have just used them for a glass hob lid for my cooker
Feb 02, 2015 | Stoves Kitchen Ranges
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
The glass has broken on the outer door of the small oven of my Stoves 1200DFa range cooker, the part is no longer made, where can I get a replacment door/glass from?
Dear Heather.
We have exactly the same problem with our Stoves 1200 DFa since more than a year.
Did you came across a solution in the mean time?I would be gratefull if you would let me know.
Thank you ,Wouter Dikker
Mar 16, 2011 | Stoves 1200DFa Dual Fuel (Electric and...
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
How to set oven programs
Hey, I've searching for a replacement manual for my Stoves Precision too... Found it here:
http://www.espares.co.uk/part/cookers-and-hobs/stoves/p/1092/630/0/0/917524/handbook-precision-1100df.html
If you buy it please use this code:
39WMTIXO
Cheers,
Apr 02, 2010 | Stoves 1100DFSID Kitchen Range
Stoves precision 1100 operators manual
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
How to fit main oven door on stove 1200 Range cooker 100 DFA
Open the door part way, then grasp the door on either side and lift up and out to release the hinge.
Jul 13, 2009 | Kitchen Ranges
Door glass shattered 3 hours after cooking
Hi there folks It also happened to me, so after ringing rangemaster they said it can happen due to faults in the glass, unfortunately my warranity had run out and they wanted t charge a fortune to repair. so i had a look inside the door my self which is only four screws on the sides to remove the outer skin to find it was a single piece of ordinary toughend glass about 300mm x 300mm fixed in place with six clips like the ones you find one those glass picture frames, i got a new piece from me local glass merchants for less than £10 and it took only mins to fix job done, I hope this help someone and it my save you quite a bit of cash Cheers folks Markbricky
May 31, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Stoves 1100DFSID Kitchen Range Logo
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
