Question about Toshiba DKT-3220-SD Corded Phone
Want to change name display on dXT3220-SD TOSHIBA PHONE
mdesmet
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Posted on Dec 10, 2007
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Posted on Feb 01, 2010
  • 66 Answers
SOURCE: How can I change the name on the display of the Toshiba phone?
By dialing intercom #621 and pressing the * key to move cursor left. press pound changes to letters and 0 is toggle. Your manual and good guides are here
http://guides.idacomusa.com/
Posted on Feb 11, 2010
  • 13 Answers
SOURCE: I need to change the name that is displayed on my
On the DK systems, you need to go into system programming, and enter the name for your extension under a setting you can access.on the CIX or CTX Phone system, you have to have a computer based software, called emanager, and program it through the computer. You may need a technician to help set that up.
Posted on Mar 15, 2010
  • 3 Answers
SOURCE: Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Posted on Mar 25, 2010
CHANGE THE DISPLAY NAME ON MY TOSHIBA DKT3210-SD PHONE
On a CiX or CTX, it's handled via the System Administration Program or Personal Programming Interface.
Sep 09, 2014 | Toshiba DKT3210SD - - Phone
Change name on display
U need to have network emanager installed on a computer
Feb 17, 2014 | Toshiba DKT-3220-SD Corded Phone
How do i change the name on the lcd display
IN THE IDIOTS GUIDE YOU WILL FIND A RESET BUTTON AND CHANGE OF DISPLAY, NORMALLY ON THEM THERE SHOULD BE A BUTTON YOU HOLD FOR ABOUT 5 SECS
Dec 26, 2013 | Toshiba DKT-3220-SD Corded Phone
I want to change the name at the top left of my LCD display. My phone is a Toshiba DP5122-SD and that person no longer works here.
This is accomplished easier if you contact the company who put your system in to program this. You can also check the users guides at
Nov 26, 2013 | Toshiba Lands Phones
I need to change the name that is displayed on my Toshiba DKT3010-SD. Please help.
Please follow the link below to download the complete manual for your Toshiba phone. It will answer your question, and you can print it for future reference.
http://www.craigcommunications.net/pdf/dkt-3000-2000-user-manual.pdf
Dec 11, 2009 | Toshiba DKT3010SD Corded Phone
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
Aug 25, 2009 | Lands Phones
Where is the Program button on the DKT3220-SD ?
press intercom #9876 HOLD, flexible buttoon pressed to assign, press the bitton code, press again the bitton to set DND = 180 short key for extn 610+extn number to change display name must set at administrator phone usually is receptionist phhone
Mar 17, 2009 | Toshiba DKT3020SD Corded Phone
Mode
Scroll
Hold
Hold (again)
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
I NEED TO CHANGE THE NAME ON THE WINDOW OF THE PHONE
wat system using?
find out the adminstrator phone (pic to set the speed dial)
must hv displayed phone.
press MODE will see PHONE NAME press HOLD display show ID DN it means key in extention number, after that key in name, press HOLD to confirm, repeat step for other extention name
press MODE untill time appear
Jan 20, 2009 | Toshiba DKT-3220-SD Corded Phone
Toshiba DKT-3220-SD Corded Phone Logo
66 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
