Question about Coffee Makers & Espresso Machines
Krups art 962 filter holder replacement
I need a replacement filter holder for a krups Espresso Novo 2100 plus Art 962 coffee maker
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SpotBert
  • 231 Answers
SOURCE: Need the instruction manual
The 866 was superceded by 874 and 888.
Here's the manual for 874 =>
http://www.krupsusa.com/NR/rdonlyres/C1F9A0BF-7C73-4009-B552-9B75D43B6DDC/2419/CAFEPRESSOF874_endefrnl.pdf
Here are the manuals for 888 models =>
http://www.krupsusa.com/NR/rdonlyres/FEFA75D6-E1B1-4AEF-86BE-86239F8F5C11/19888/88843CafeCentro.pdf
http://www.krupsusa.com/NR/rdonlyres/55222C7A-5B29-4DD2-9828-679A73F140F0/7908/F888_NAm.pdf
http://www.krupsusa.com/NR/rdonlyres/A025B3F7-4253-45C9-95CA-AF3036FD2914/2430/CAFEPRESSOTIMEF888_multi.pdf
You can call KRUPs to see if there are any major differences.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: instructions for Krups Gusto espresso maker
I found the manual on an Amazon.com site for the Krups Gusto espresso maker (January 2009)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Posted on Jan 18, 2009
SOURCE: I have a Krups type 964 espresso maker - I can't get a good seal
the seal on the filter is broken? its a replacement part
Posted on Jun 23, 2010
No coffee is coming through, I guess it needs descaling. How do I do this? Note my machine does not look like the one in the picture. It does have KP2000 on it though!
remove every thing filter holder ecc then try again do not do any descaling as yet you may block the system even more first get the water to flow and make sure you clean all the filters be for hand good luck
Feb 10, 2016 | Krups Espresso Novo 2000
Why is my dolce gusto is leaking. can it be repaired?
remove the plate which is clipped neat the capsule holder and try again if it works see if you can opening the hole or replace
Oct 05, 2014 | Krups Dolce Gusto KP 2100 Espresso Machine
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
The milk steamer is not frothing. I have tried cleaning and descaling
If it does not produce steam when you switch to steam mode and wait for it to heat up, the steam thermostat needs to be replaced.
Mar 03, 2011 | Krups Espresso Novo 2100
I have a krups type 962. the washer broke around the top of the filter. I took the filter of but need to replace the filter, where do i buy these from???????
Here is the link for the Krups on line store.
http://www.krupsonlinestore.com/product_list.asp?SKW=PARTF985&SEARCH=&MENU=parts&SELECT=coffeemachines&PGN=1
This is the link for your brewer.
Jan 19, 2011 | Krups Caffe Duomo 985-42 Espresso & Coffee...
I have an Krups Novo 4100 Programatic. The pressure builds up and is then released into the overflow tray. I can get it to work by running through the citric acid and cleaning the shower but only for...
Hi
In the filter carrier (the handle thing) is a small o ring. I think it keeps the filter pressurised which helps create crema. After a while the o ring gets pulled out of shape and doesn't let anything through. Remove the screw in the top filter, pull out the steel filter, the plastic disc under that (might need to pry it out) and you will see the mis-shaped o ring. You can get a replacement from an appliance repair place. I have just read today that you can also just leave it out - but you will need to tamp the coffee (squash it down) more. Hope this helps.
Nov 10, 2010 | Krups Espresso Novo 4000
The hard plastic gasket that fits 1/2 of the seal has fallen off - I can manually put it back in place each time I make espresso, but it doesn't always stay in place. How can I get a replacement?
Here is the contact info for the authorized Krups parts vendor. I was not able to locate the exact part as the number off the bottom of the machine is required. They should have no problem getting you a new gasket. Hope this helped some:)
Aug 27, 2010 | Krups Espresso Novo 2100
Same Problem - no water goes through in either mode
remove screw in centre of group head and remove valve and spring, clean and reinstall.
Sep 21, 2009 | Krups Espresso Novo 2100
Brought this second hand yet it has no instructions please help??
My machine just died, did you want my instruction manual
Apr 06, 2009 | Krups Espresso Novo 2100
I need a 2-cup filter
GOOGLE "2 cup filter for Krups espresso Novo 2100"and your problem will be solved.
Jan 29, 2009 | Krups Espresso Novo 2100
Coffee Makers & Espresso Machines Logo
63 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
