Question about Compaq 2710p Tablet PC
Where the bios chip located in hp compaq 2710p
When l switch on my 2710 it has a black screen and says non system disc or disc error
Either the hard drive is bad and needs to be replaced, or the operating system has corrupted and simply needs to be re-installed. HP's usually have a DFS test in the BIOS menu to see if your hard drive is faulty.
Dec 03, 2012 | Compaq 2710p Tablet PC
I want software and drivers for 2710p for windows 7
Hi John this link should help
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3355644
Jun 06, 2012 | Compaq 2710p Tablet PC - Intel Centrino...
Hp 2710p ram cannot go 3Gig
Hi Are you running win 7 32 bits?enterprise?
Jan 28, 2012 | Compaq 2710p Tablet PC
Cant find drivers for HP Compaq 2710p touchscreen.
Hi hbeach1998,
To download drivers for your Compaq 2710p:
  1. Visit www.hp.com/support.
  2. Click "Drivers and Software."
  3. Enter "compaq 2710p" in the "Enter a product name/number" field and click "Search."
  4. Select your computer's operating system from the list.
  5. Click the "Download" button next to the driver you need (they're sorted by device type) and follow the on-screen instructions.
I hope this helps!
May 26, 2011 | Compaq 2710p Tablet PC - Intel Centrino...
I need reset bios password Notebook HP Compaq 2710p
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: reset BIOS Password?
So I would suggest you the 1st method. Hope it helps.
Aug 30, 2010 | Compaq 2710p Tablet PC
Disable BIOS Administrator password
Enter BIOS SETUP. Enter the current password.
Change it to a "blank" password.
Or, if you don't know the password, find the orginal sales-receipt, to prove to HP that you are _NOT_ a thief in possession of the stolen computer, and then HP will assist you.
Aug 24, 2010 | Compaq 2710p Tablet PC
Hp 2710p touchscreen and or stylus not working
Probably the connector between screen and mobo has come loose, it a common problem, I had the problem on a Tx1000, remove the battery, and underneath is a small casing, remove that and there should be several connectors, check and see if they are all inserted
Jul 12, 2010 | Compaq 2710p Tablet PC - Intel Centrino...
HP 2710P will not power on!
Try power draining your computer first. remove battery and ac adapter, then press and hold power button for 15-20 sec. Expect no response since there is no power source. After that, try if pc will now turn on. If it still wont, possibly it will be needing a motherboard replacement.
Apr 26, 2010 | Compaq 2710p Tablet PC - Intel Centrino...
How to remove cmos battey to rest bios in hp 2710p laptop
Go on your manufacturer's website, find the maintenance manual, find where is located the battery and just remove it for a few seconds it may remove the password on your bios. Good Luck!
Mar 23, 2009 | Compaq 2710p Tablet PC
My HP Compaq 2710p will not charge
I PUT A HEAT SINK FROM A CPU AND ATTACHED COOLING FAN TO THE HEAT SINK
AND THAN ATTACH IT TO THE BLACK OBLONG LONG RECTANGLE BOX LIKE OBJECT AND IT WILL STAY VERY COOL AND ALSO SAVE THE BATTARY FROM OVER HEATING AND DAMAGING THE BATTERY.
RODGANDYSR
Mar 07, 2009 | Compaq 2710p Tablet PC
Compaq 2710p Tablet PC Logo
47 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
