Question about Sony DSC-T7 Digital Camera
Blank white screen sony DSC t77
Brand new camera with full charge and correct memory stick all I get is a blank screen. does anyone know how to reset to factory settings on this model??
To Power Reset the Camera, please remove the Battery from the Camera, press and hold the Power button for 30 seconds and then reinsert the Battery.
Another option: I took the battery out and I pressed Menu and Shutter button for 30 seconds and it worked! The screen is back!
Posted on Jun 11, 2009
  • Asha Shet Aug 26, 2012
    i pressed power button for 30sec still it won't work the screen is still white.Any other solutions??
    President:
  • 1,223 Answers
CCD failure !! if u dont see anything on screen takes white or blank pics reset will not help !
but try u might get it repaired free bcoz this is manufacturing default in whole batch of CCD's fitted by variousbrands so they are taking repairs free of charge even afterwarranty sojust email or call them even if ur camera is not on listthey will doit free of charge dont worry just contact them PLS RATE MEFIXYA for help
see this
http://www.imaging-resource.com/badccds.html
see this link for ur support
http://esupport.sony.com/US/perl/model-news.pl?mdl=DSCT7&LOC=3
call blank white screen sony DSC t77 - cb_transparent_l.gifus.gifspblank white screen sony DSC t77 - space.gifclass=arrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-866-703-7669cb_transparent_r.gif.
Posted on Mar 21, 2009
How do I format sony cyber shot DSC-T77 memory stick duo?
Press HOME icon on screen, then go to Memory Tools and you will see Format option, select it and press Yes to format memory stick in camera.
Thanks.
May 18, 2010 | Sony Cyber-shot DSC-T77 Digital Camera
Dsc-f717
The Sony DSC-F717 will only take upto a 256MB Memory Stick - larger size Memory Sticks will give the C: 13:01 error. Use a correct memory stick and your camera should be fine. Regards, Andrew
May 10, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
How to down load pictures from camera (sony 1080 cybershot) to computer
ok u hav some options: > use ur usb cable > take out ur memory card, buy USB CARD READER OR A LITTLE USB THAT U CAN PUT MEMORY CARD IN then either put in correct slot or put in the dongle and plug in comp voila!
Jun 14, 2009 | Sony Cybershot DSC-T77 Digital Camera
Sony DSC T77 How to Setup Black and white mode
Hi Allonsoma,
What the manual doesn't tell you is that you need to change the REC mode first to be able to fint the buttons in MENU.
Fist go into the REC mode (the one above menu when taking a photo). Change this to PGM and click OK. Now go into MENU, on the 3/4 page second button down should be a box with a + in the corner. This is the colour mode option. You can now change to vivid, sepia or black and white.
Hope this helps.
Mar 26, 2009 | Sony Cybershot DSC-T77 Digital Camera
Sony t77 digital camera
You can change color picture in to black & white as following..
Set camera in playback mode. There is 'Retouch' option in camera Menu. You can make changes in pictures like black and white and save as new file in memory.
If you need user manual, click Sony Support and download copy and go to page-46 for menu items.
Mar 18, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Sony cyber shot DSC H50 keeps reading "turn camera off and on aga
The error you are getting is because of either System Error or Internal Memory Error.
I think you might need to take it to Sony since it is brand new. But Before that, I suggest that you take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and try to power on. If you are lucky, you might not need to go to Sony
Mar 05, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Damaged LCD t77
No parts available for trhis type of product - replace the whole item.
You could look on E-bay - but then you have the fitting problem- can you do that?
Jan 28, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
My sony dsc-s40 has only a blank white screen does not work properly
Happy New Year!
My Mom had this same camera and had -what sounds like- the same problem. I found that the connection to the screen was loose. Take apart the camera- you need a tiny philips. If I remember there are only three screws you need to get to. One near the battery compartment. one near the tripod mount (bottom) and one just inside the memory stick slot.
Jan 03, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Memory card for sony dsc-t77
i used a "Sony Memory Stick® PRO DuoMark 2" it also comes with the adapter so you can plug it in the computer. hope this helps!
Dec 29, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Sony DSC-T7 Digital Camera Logo
443 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
