Question about Samsung RS267TD
Ice maker bin - Samsung RS267TD
3 Suggested Answers
SOURCE: ice maker
We just figured out our ice maker suppot try is broken and won't allow the ice maker to twist the ice out when it flips. We purchased a new support piece on line. I saw your problem which sounded similar to what was happening to ours. If you need it, the part # is DA61-02205A. Good luck.
Posted on Jul 22, 2008
  • 864 Answers
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
Posted on May 29, 2009
The Ice maker is not making ice. The water is on is there a reset button?
No Reset call the manafacture or go the Store where you bought it and get an Exchange sound like its defective
Mar 06, 2017 | Refrigerators
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Samsung RS267TD Logo
23 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
