Kyocera 220 error c6000 - Office Equipment & Supplies
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
FixinFax
  • 3085 Answers
SOURCE: My Kyocera Mita KM-KM 1635 displays error call c6000
Have the FUSER replaced.
Posted on Mar 04, 2010
  • 74 Answers
SOURCE: Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
Posted on Mar 27, 2010
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
Have error C6000 on kyocera taskalfa 220. and no any button work.
You have to go to simulation 1087 -1087- then press 163 then execute and print baton and clear then 01 to Exit then OFF the machine and after 10 sec ON . the problem will be solved
May 23, 2015 | Kyocera Office Equipment & Supplies
How to reset c6000 error on Kyocera M2535dn?
try replacing the fuser it says broken fuser heat wire
Jul 23, 2014 | Kyocera Office Equipment & Supplies
Kyocera c6000 error
Fuser error try to reset it otherwise if it didnot work, change fuser unit
Nov 26, 2013 | Copystar Kyocera Taskalfa 181 Copier
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
Have error: C6000 on Kyocera KM-3050
Aug 02, 2008 | Office Equipment & Supplies
29 people viewed this question
jasbo
jasbo
