Question about Whirlpool Ovens
Oven temperature goes on and off or keeps returning to 160 degrees
Type FCEM9 AKZ160/WH SERVCE 8585 160 15010 14 9946 007101
SOURCE: Oven temperature
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Posted on Dec 06, 2007
SOURCE: T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Posted on Oct 11, 2008
SOURCE: Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Posted on Feb 13, 2009
arepairman
  • 20 Answers
SOURCE: The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Posted on Mar 14, 2010
SOURCE: I have a 4 year
Neff Cooker manual, Neff instruction manual for ovens
Here is a link for you to download a PDF instructional manual for your Neff cooker or Neff oven.
how to use this service
1 click on Link,
2 on the left hand side click manufacturer (Neff)
3 then click on service
4 then click on service and select instruction manuals
5 enter your model number and download the PDF file .
http://kundendienst.consultens.de/gb/BSH_Appliance_Care.htm
I think you will find that it is your Thermistor, or Thermostat that has faulted, this is usually what it is... Sometimes it is the main controller that has been spiked.
You will in any event have to troubleshoot via your service manual
Posted on Aug 24, 2010
Oven heat sensor
yes. is it under warranty?
Nov 09, 2013 | Ovens
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
42 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
