Question about Philips Office Equipment & Supplies
Philips laser mfd 6050 user manual/guide
How to change the toner cartridge
SOURCE: user or trouble shooting manuals for Canon Laser Class 710
The original problem was the lighter print out. Both from the fax and the scanner. I am a professional in service, only I have no certification or support from Canon.
I do want to thank you for your response, but in the interan, I have managed to resolve the issue but taking the machine apart and removing the laser unit. Taking it apart and cleaning both the lenses in it . The machine is now running about 85% better. But I never did find a way to get into the printing menu to change the settings. Thanks again. Pat
Posted on Jan 19, 2008
EPIJAB
  • 89 Answers
SOURCE: Refill Toner Cartridge for Laser Printer
I work for a company that does this and can tell you it is possible. Some companies do the drill and refill and some like mine actually take the cartridge apart and replace the drum and wiper blade.
You can buy the kits to refill your own. Usually, it just involves drilling a hole and pouring in the toner. This is the first I have heard of the melt and pour. Just be aware that eventually the parts inside will wear out and start to show image defects. You don't recommend reusing them more than twice.
Posted on Feb 15, 2008
asish_shrm
  • 121 Answers
SOURCE: laser printer not printing properly
Since you have changed the tone cartridges ...and it still does the same....
the next step is to check the transfer belt..transfer roller(this when hit by laser light stores the image and runs on the powder ink..the parts that have been created by the laser on the transfer belt is where the powder sticks)......remover the transfer belt roller and check to verify that its not worn out..its in the form of plastic paper more like Teflon.....view to see that it doesn't have severe markings...if its marked you will need to change the transfer belt to
If this doesn't fix the problem than you will need to change the laser scanner unit....
so basically its your cartridge...that provides color powder dust for image....
transferbelt...that transfers the image to the paper with the image being created by the laser scanner and the cartridge providing color
the last process is fussing ...heat is used to make stick the powder to the paper..and is done by the fusser unit...
as for your case the image is not either created by the scanner itself in the right manner..or the image is not properly created coz the transfer belt is worn out....
I suggest you replace the transfer belt next.
cheers!
Posted on Nov 12, 2008
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
  • 133 Answers
SOURCE: Toner cartridge needs replacing in brother hl-20
if you want to replace your toner,
First you just need to open your front cover and pull out the toner and drum.
after that, push down the blue buttom on drum and pull out the toner. Then replace the new toner into the drum.
finally, just push back the drum and toner back into the printer.
Posted on May 23, 2009
How do i download and install my philip laser mfd 6020 printer
Go to Philips.comsupport, and click on "contact". Have the full product number available. Pose your question to Philips. Usually going directly to the source, will bring you the best results.
Jan 04, 2015 | Laser Office Equipment & Supplies
Toner cartridge
It's probably s non original or a re manufactured toner ,make sure you get an original manufacturers toner and problem should go away ,if you still have a problem you may have donebothercservice issue and need a qualified service person to look at it
Mar 25, 2014 | Philips LaserMFD 6050 (LFF6050)
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Oct 02, 2010 | Brother FAX-2920 Plain Paper Laser
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Driver and Manual request...Pretty Please!
The Canon NP 6050 is an analog copier, will not connect to computer for printing. I can come up with a User Guide for it, if desired, but not the service manual.
As far as the Canon Digital Colour Laser Printer.....what model is it? What operating system are you using?
Jun 12, 2009 | Canon NP 6050 Copier
Ink cartrige dell 1110
Maryfrancesh
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
http://support.euro.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The guide also contains pictures of what to do.
Andy
Jan 29, 2009 | Dell 1110 Laser Printer
Konica 1400 page pro
Toner Cart is combined with Drum Cart in what's called an "Image cartridge" did you followed user manual instruction to change it?
Let me know if you have the instruction from User manual: I can send it.
Nov 24, 2008 | Konica Minolta PagePro 1400 Laser Printer
How do you change the magenta, yellow and black toners on the dell 3100cn
The toner carousel must rotate, so that you get the slot for the other toners in front of you.
Follow detailed instructions on the user manual, click here to get the manual :
Owner’s Manual
Nov 07, 2008 | Dell 3100cn Laser Printer
Replacing toner on mf-jet 500 philips fax
This link gives you the user manual for mfjet 500 - page 23 for cartridge changing (Sagem have bought fax support from Philips) http://www.sagem.com/support/site/livret/um_mfjet500_uk.pdf When you get a new cartridge there are usually very detailed instructions on the packet too Hope this is what you need, if not then contact Sagem on http://www.sagem.com/support :)
Feb 28, 2007 | Philips MFJET 500 All-In-One InkJet...
118 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
