Question about Canon imageRUNNER 210S Copier
Error E000 sir, i having canaon image runner 210S my machine frequiently shows the error E000 , After some time i.e. after 10 to 25 minuts this problem goes & machine runes smoothly this problem comes within 2 to 3 days. can you guide
  • raj140m Jan 09, 2009
    thanks for giving me a solution for the problem error E000.
  • Anonymous Mar 13, 2009
    OUR CANON IS DOING THE SAME THING.... ANY HELP?
  • Canon Expert
  • 1,326 Answers
First of all a E000 is a power proble that the fuser is not warming up in time or power is not avaible. Is it possible that you may not have a outlet just for the copier by it self.... It could be low on usable power. If the power is good, I would say that your Upper heating unit is shorting out from time to time. You will need to have to replace the fixing unit if it is to much of a pain to deal with.
Posted on Jan 05, 2009
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Error000
This error means that the Fixing heater is not working. It has not reached operating temperature after a specified time. It has probably blown the heater element.
You will need a trained technician to repair this.
E000 errors will not clear until the fault has been rectified and then reset by a technician. This is to prevent any fire risk.
Apr 30, 2010 | Canon Image Runner 1630 Copier Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
The Screen on Canon Image Runner says E000 - can't make copies
Your Fuser just went , Call you Canon independent or Authrized dealer, he will need to go into the simulation to reset this error. Usually E000 is either a fuser or fuser web error. I'll need to look this up in the service manual. most likely you'll need a quailify technician to reset this error code.
Mar 04, 2009 | Office Equipment & Supplies
Canon 330 image runner Error code E000
E000 is a fuser problem.
take out the fuser (this is where the paper exits and gets hot) the tow long big rollers, the lamp may have blown or the thermofuse (keeps the copier from over heating and going to meltdown) may be bad.
The newer ones (not sure about this model ) have a ceramic instead of a heat lamp and also a thin brown film instead of rollers.
if it has a film make sure it is not torn or displaced.
Nov 21, 2008 | Canon imageRUNNER 210S Copier
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
Image Runner 210S
it is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
Apr 20, 2008 | Canon Image Runner 3320I Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 210S Copier Logo
117 people viewed this question
old marine
old marine
