Question about Hoover Nextra HNWL 3166 Front Load Washer / Dryer
Hoover nextra washer dryer won't dry - Hoover Nextra HNWL 3166 Front Load Washer / Dryer
  • 1462 Answers
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
SOURCE: programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Posted on Jun 01, 2009
FitzOriginal
  • 842 Answers
SOURCE: hoover nextra hnf2137 wont drain
Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning Hope this helps
Posted on Feb 02, 2010
SOURCE: HOOVER NEXTRA HNL71663D WASHER DISPLAYING E05
I had exactly the same problem. After removing the back panel, I checked the two wires that go into the thermostat, they came away with no problem (not a good thing). Both of the wires were very brittle. I restripped them back and put two new connectors on, the problem was solved. Sounds obvious but make sure you turn the power off!
Posted on Feb 04, 2010
  • 57 Answers
SOURCE: Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Posted on Mar 31, 2010
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
cheers
Aug 30, 2017 | Hoover Washing Machines
User's Guide HOOVER HNWL 7146 Nextra 6 Washer Dryer
Hi if you give me your email address I will send you a nextra 6 user guide
Dec 01, 2011 | Washing Machines
I have a hoover hnwl 6136, and it's not drying properly. Presume I need to clean the filter but I cant find it?! Help?!
I have the same problem. Do you have a manual for this washing machine/dryer (HOOVER HNWL 6136)? I looked everywhere for a manual and I couldnt find one. If you can email it to lettings@fesamuels.com it will he much appreciated.
Oct 07, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Does not heat up when drying clothes
heating element is most likely shot.
good luck
please mark the post with a fixya
Feb 19, 2008 | Hoover Nextra HNWL 3126 Front Load Washer...
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWL 3166 Front Load Washer / Dryer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
